Question about Apple iPod nano 3rd Generation
Ipod won't turn on unless I reset it?!?
I recently got a third generation ipod nano and it won't turn on no matter what button I press. i have to reset it (toggle hold button and hold center and menu button until apple icon appears) every time I want to turn it on. And it usually takes several attempts to reset! Why is this happening and is there any way to fix it? I've found lots of info on people having the opposite problem (it won't turn off) but nobody seems to know why it won't turn on! Please Help?!?
  • 6 more comments
  • Patrick Stallings Feb 27, 2008
    I am having the same problem with a 2nd gen ipod nano 8GB. It will not turn back on after going to sleep unless I plug it into the PC via the ipod USB cable. Once I do that it turns right back on and will play for as long as I don't turn it off or the battery runs out.
    Also it will not reset, no matter how many times I hold the menu and center button down.
    Please help!!!
  • zaclove14 Mar 03, 2008
    i got an ipod nano for christmas and all of a sudden it won't turn on no matter what i do. They say on every website that you should reset it or restart it but it still won't turn on. I am getting upset because i love my ipod like it is my own child. if anyone else has this same problem, write a comment to help or pleasegive some kind of a solution. Please help me!!!!!!!!
  • brooke_64 Mar 12, 2008
    I didn't do anything to it. It won't turn on no matter what i do? I push buttons but it is just a black screen!!! help!!!
  • crow devil Mar 26, 2008
    lke i plugged it up 2 my computer and i have tried everything 2 fix it but it still wont turn on!!!!help!!!
  • kainoa Mar 27, 2008
    the thing wont get off hold. i tride to tern the hold swich off and back on and ive tride to hold the sinter and the menu button down but it still dont work
  • Anonymous Sep 30, 2008
    i need help i am scared
  • colinsp Nov 20, 2008
    Same with me been working fine for 18 months and suddenly started not turning on without a reset.
  • Anonymous May 03, 2009
    I have an Ipod Nano 3rd Generation and I have had it since christmas 2007. The other day I went to listen to my IPod and it wouldn't turn on the same problem has happened about 4-5 times and I managed to get it working - Help Please !!!
    Sergeant:
    Champion:
  • 322 Answers
If under warranty i would take it back rother than go throw all that agro as it a internal problem and only can be fixed by manerfactures
Posted on Feb 18, 2008
My ipod nano third generation is frozen
You should not plug the ipod to pc while it is playing because it is switches from the playing mode to sync and charging mode you can not play and use the ipod while it is connected with the software without ejecting it from itunes. Do a reset by pressing and holding the center and menu buttons at the same time until the screen goes back and apple logo pops up. This should reset your ipod and fix the problem.
Feb 20, 2009 | Apple iPod nano
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
Ipod Nano 3rd Generation volume problems
ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
Aug 17, 2008 | Apple iPod nano 3rd Generation
Volumn locked on ipod nano 4gb third generation
Press and hold down the center button while pressing on the menu button.
This will reboot your IPod.
Jun 21, 2008 | Apple iPod nano 3rd Generation
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Sep 07, 2007 | Apple iPod nano
Ipod Nano Second Generation
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Frozen ipod
Aug 02, 2007 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
82 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
