Lennox c23-41-1 Think the problem is flame sensor. Any place I can find a how-to?
  • 308 Answers
Trying to find information on a Lennox furnace is very difficult, they only sell to factory authorized installers. If you have a flame sensor that you think is defective, here is how to check it. Check, with an ohmmeter, the resistance from the tip of the flame sensor to the connector that plugs into the board (on the end of the wire) you should read no resistance. Check the resistance between the flame probe and ground, with the flame probe installed in the appliance, you should get OL or infinite resistance. Hope this helps
Posted on Jan 30, 2010
Lennox G21Q fires then shuts off 1 or 2 times before staying lit???
I would check all wiring connections going to control board and all other components that are easily accessible just to make sure all are making good connections.I don't really think this is the problem but it cheap ,easy,and don't take much time to do.
I would locate flame sensor and clean it of any carbon of rust.The sensor should be a small diameter metalliic rod that is usually located on one end or other of the burners and extends slightly above burner. There should be a sensor right beside thr ignitor but it is to sense that the ignitor is working. You should be able to clean flame sesor with fine sand paper or steel wool. If you need to remove flame sensor to make it easier there are generally only one or two screws holding it in place. Best of luck to you. Thank you. Frodo
Apr 17, 2011 | Heating & Cooling
I have a Lennox Gas Heater that will work for a while and then stop working (or fail to turn on when it cools down in the house). I changed the thermostat in the hallway about 6 months ago so I don't think...
Hi, i've found out that the flame sensor (rod that sits within the flame) is fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once you pull out the rod and cleaned it with a wire brush, it should fix the problem whatsoever.
Mar 05, 2011 | Heating & Cooling
Lennox intermitent flame problem
Yes the flame sensor is not allowing the ignitor to start, you will need to remove the flame sensor, and clean the black carbon build up from the stem of the flame sensor, replace the flame sensor and turn the furnance back on, this will correct the problem.
Dec 10, 2009 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
How do I clean a flame sensor on a 1993 Lennox Whisper Heat furnace. It heats,then the gas valve clicks and the flame briefly stops and starts again then the valve clicks again and the flame briefly stops...
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Nov 11, 2009 | Heating & Cooling
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
Gas does not stay on.
get a volt meter and check and see if you loose 24 volt power to the gas valve then make sure your grounds are goodif thoose are ok check for a 24 volt drop on transformer
Nov 16, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
779 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
