Programming remote Hi,  I am trying to reprogram my RCA universal remote to work with this receiver but I have not been able to find the receiver code again.  The Sony website does not have my model.  They do however have the replacement remote for sale! sony receiver STR-D615 serial # A771701
    Sergeant:
    Champion:
  • 281 Answers
Www.download.com
Posted on Feb 18, 2008
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Unable to control volume to the receiver with my universal remote
There has to be another code for this then. Remotes have a way of manually programming them by going through all available codes known and not just the listed code that is supposed to work. I would follow the instructions for that method to find the proper code.
Nov 11, 2012 | RCA RT2350 System
I need the code on a paramax audio receiver p-701 for a universal remote.
Hi, you need to refer to you instructions book that came with your RCA remote when you purchased it new. It will have all the codes and instructions on how to program the remote inside the book. But all said and done, even if you find your original manual for your RCA remote and programmed it. It will probably still not work because RCA universal remotes arn't made very well to be compatible to receivers.
I suggest getting your original remote if it is still available. Try going to Replacement Remotes, as they have most all original remotes available and you will not have to program an original remote from them. Search for your model of receiver in their search box.
Oct 08, 2012 | Televison & Video
Anyone have the code to reprogram the remote for the t.v
A universal programmed for almost any of the older rca or ge codes will work; A universal RCA should not require any programming.
Mar 17, 2012 | RCA P52921 52" Rear Projection Television
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
My RCA Universal remote is not working (will not turn the TV on or off). There is no poroblem with the battery.
The remote may have lost the code for the TV. Reprogram the remote.
I hope this helps.
(I had a universal remote that would lose the program code due to the program button being pressed when the remote was picked up or put down.)
Jul 05, 2010 | RCA Universal Remote Control
Antenna button not functioning on RCA300x universal remote
U have glitches in the reprograming back and forth.Take the battery out,about an hour.Reprograms the codes again,should work again.Don't reprograms the codes back and forth to many times or one times to many will kill the remote for good.U have 2 tvs,U should have 2 tvs remotes.
Jun 22, 2010 | RCA RCU300 Remote Control
I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
Jul 08, 2008 | Televison & Video
195 people viewed this question
 Grubhead
Grubhead
