Question about Samsung SGH-G600 Cellular Phone
I already purchased samsung PC studio 3 and loaded it but still get a message "not recognizing device" when I try plug in my usb cord with the cel phone attache. What is the correct software for a Samsung E2210 cel phone?
Unplug the phone from the pc, turn the phone off and on and then reconnect it, it worked with mine !
Posted on Feb 03, 2010
Purchased a USB cord to download photos from my phone. Can I use it without having a disk to install it into my computer?
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Dec 08, 2011 | Pantech Cell Phones
Samsung E2210L Connecting to PC wont recognise
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make
Apr 10, 2010 | Cell Phones
Set up NPS
while installing setup for samsnung mobile..a message appeared "NPS not exist "..wat do i do??
Aug 27, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Usb not recognized
you can try this. install pc studio, and then connect your mobile...it should automatically install the drivers..but if that is what you have done then you can try updating the PC studio software.
Nov 29, 2008 | Samsung SGH-D900 Cellular Phone
Syncing won't work
youll need the drivers for them i cant find them online but you may want to try bitpim its a free program that would let you do it without drivers
Apr 01, 2008 | Samsung SCH-u740 Cellular Phone
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Problem with YH-925
It appears you need to use the rollback program, or the recovery program. But it also sounds like your usb cord is either broken or not plug in tightly. Press the usb adapter in untill you hear a click then plug it into the pc.
Feb 10, 2007 | Samsung YH-925 MP3 Player
Samsung SGH-G600 Cellular Phone Logo
88 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
