Question about Samsung RB1955 Bottom Freezer Refrigerator
How do you adjust the water level setting a Samsung icemaker
Samsung fridge freezer combo. Ice cubes are stuck together into a block. How do I adjust the water level for the cube tray?
SOURCE: Samsung, american style fridge
We had a service tech service our fridge for the same problem. Although the ice that was dispensed was not as fine as crushed ice, mainly chunks. In any case, he said this is a known problem and is typically resolved by ensuring the freezer temp is not set at the maximum setting. Ours is currently now set at 3 bars and is producing cubes. Not sure if reducing the temp was the ultimate fix as he also replaced the ice maker.
Posted on Aug 05, 2007
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
  • 883 Answers
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
  • 1073 Answers
SOURCE: Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
Posted on May 06, 2008
  • 489 Answers
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Posted on Jun 08, 2008
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Large blocks of ice in icemaker keep ice from dispensing. Hotpoint side by side fridge/freezer combo.
there is an adjustable screw on the side of the icemaker for how much water is let into the tray to be frozen.
Aug 22, 2009 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
The individual cubes turn into a huge block of ice
After the ice maker dump the ice it calls for water and pour water for no more than 7 seconds if is more and overflow the ice tray will leak on the ice bin and freezes all together , that means that the circuit board inside the ice maker is bad and need to be replaced but it will cost you almost as replace the ice maker and is easier ,two screws on the top of the ice maker and one in the bottom,a plug between the ice maker and the freezer wall ,and the plastic tube from what the water come into the ice maker.
Apr 07, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
Samsung RB1955 Bottom Freezer Refrigerator Logo
639 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
