Question about Danze Plumbing
REcently installed Danze Ashburyee kitchen faucet - 063-4463-4. Small leak coming from where the spray hose connects to the hose coupling coming from the faucet above. Solutions, is the cartridge?
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
Posted on Jan 31, 2010
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
Mar 16, 2013 | Moen Monticello Single-Handle Kitchen...
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
My danze kitchen faucet is loose and wobbly i cannot seem to tighten it i no longer have my installation insructions. please help. how do i do it?
You can see the installation manual here:
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
Hope this helps! Remember to rate me, thanks.
May 26, 2010 | Danze D403412 Melrose Single Handle...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Don't know what side allen key to use on danze D456513SS to fix a leak?
Buy a cobination set of allen keys usually between 1mm to 10mm and use the one that fits
Jun 17, 2009 | Danze D403412 Melrose Single Handle...
Handle is leaking from the black casing when I turn on the spray
If there is no removal of the item then a new faucet is needed. good luck
Jan 13, 2009 | Danze D403412 Melrose Single Handle...
Plumbing Logo
658 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
