Question about Star Micronics TSP600 Thermal Printer
My star tsp600 printer wont stop printing "12345@pjl enter language=pcl3gui"
shaggyrat
  • 1224 Answers
SOURCE: star tsp600 driver
http://www.star-emea.com/techsupport/drivers.html
heres the link for the drivers your looking for there in zip format hope this helped you a bit
Posted on May 22, 2008
  • 9 Answers
SOURCE: i have a star TSP600
Either the connector on the printer is bad where the adapter plugs in or the printer logic board will have to be replaced.
Posted on Feb 23, 2009
  • 59 Answers
SOURCE: hi i can't seem to get it so i see my star tsp600
Here's a link to the driver download page. http://www.star-micronics.co.jp/eng/dl/dl02_06_02spsd.htm
They have an odd setup utility that will extract the drivers and then run windows add printer wizard. If it's an ethernet connection you may have to use the auto install utility to detect the printer. Keep in mind that the driver has 2 versions one is the basic driver and the other is with a status monitor.
How is the printer setup?
USB/ethernet?
direct conection?
Posted on Jun 10, 2009
  • 97 Answers
SOURCE: My star tsp600 has stopped working properly. The
You will need to take the printer in for a service. The cutter is Jammed and that causes the fault on the paper feed.
Posted on Aug 05, 2009
STARTSP600 تعريف طابعة
Posted on Dec 21, 2009
I replaced a tsp600 with a new tsp600
There are DIP switch settings in the printer, Check the old one and change the new on to match.
Feb 22, 2014 | Star Micronics TSP600 Thermal Printer
I have a Star TSP600 Thermal Printer which is displaying a red error light.
Are you sure the paper is correctly routed? It will pass a detector. Mis-aligned paper, or defective/damaged detector will present the error.
Nov 08, 2013 | Star Micronics TSP600 Thermal Printer
My tsp600 receipt printer will not print and the error light is on.
Dear Oasis Pools,
Please advise if the error light is flashing or solid. Also, perform a self test by turning the printer OFF, hold the feed button down, then turn the printer ON at the same time. A self test should print out. Did this print?
Regards,
Star Customer Support
For further assistance, please contact our Support Team at 800-782-7636 Option 2 for Tech Support or support@starmicronics.com
Feb 13, 2011 | Star Micronics TSP600 Thermal Printer
Will not print correct as a network printer
1. Define your Star Micronics Printers device model TSP600
2. Define your operating system to install your Star Micronics Printers device
3. Search Printers driver category
4. Find Star Micronics Printers driver
5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
8. Restart or reboot your computer to finish your driver installation.
Download here:
http://www.opendrivers.com/driver/247183/star-micronics-tsp600-printer-network-setup-utility-ver.-2.0.1-windows-xp-2000-me-98-95-free-download.html
Aug 16, 2010 | Star Micronics TSP600 Thermal Printer
My Panasonic Priter kx-p2130 keeps printing the same line over & over: @pjl enter language=acl
the print job was cancelled. so close the computer & printer wait 3 seconds and put it on then make sure there is no jobs to print by going to control panel, then printers
Jul 12, 2010 | Panasonic KX-P2130 Matrix Printer
Im using a Star TSP600 printer, it respond to the computer but the paper prints a lot of quetion marks insted of the normal text, what mite be the problem
Make sure the dip switch settings are correct. This is probably a serial interfaced printer and the baud rate or parity is wrong. Do a self test on the printer by holding down the feed button and turning on the printer, release button after the printer starts printing the test page. Now make sure your computer settings match the printer settings exactly.
Apr 10, 2010 | Star Micronics TSP600 Thermal Printer
Nothing happens!
this usually happens when ur printer is lacking some input like a response from ur cpu or even ink..... make sure everything ur printer needs is there..
Feb 08, 2010 | Star Micronics TSP600 Thermal Printer
My star tsp600 has stopped working properly. The auto cutter no longer works and the receipt paper does not advance fully.
Aug 05, 2009 | Star Micronics TSP600 Thermal Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
Star tsp600 driver
May 22, 2008 | Star Micronics TSP600 Thermal Printer
Star Micronics TSP600 Thermal Printer Logo
105 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
ray gallant
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
