Question about Apple iMac G4 Desktop
Computer won't start up correctly
When I start the computer, it goes to the gray Apple screen with the little circle that keeps going around and stays there forever. I tried starting it up in Safe mode by pressing the shift key when I started it. It went to the same screen and the little circle went around for maybe about 20 minutes and then went to a blue screen with the circle still going around. Finally it is at a blue screen with nothing on it at all except the mouse arrow. What do I do now to solve this problem.
This problem started when two days ago it accidentally became unplugged and we tried starting it again.
    Guru:
  • 206 Answers
Considering you have tried the Safe Boot mode to correct this, try to resolve this from the hardware side:
Procedure #1:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the star tup sound for the third time.
• Release the keys and allow the Macbook to start up.
If the iMac still does not start up to your Desktop correctly, go on to the next procedure:
Procedure # 2
-PMU RESET-
The Power Manager is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect all the connections going into the Mac except for the Power cord.
• Once all connections have been disconnected, remove the power cord from the iMac.
• Wait 1 minute.
• Reconnect the keyboard, mouse and power cord back into the computer.
• Press the Power button to restart the iMac computer.
• Observe if it starts up to the main desktop this time.
If it does not however, you may have an issue with your current Mac OS X directory or the issue could be hardware related.
Here is a comprehensive reference for you regarding Additional Troubleshooting for Blue, Gray screen issues and more, that you can also review:
Apple Support Link:
Startup Issues for Macs
If all else fails, you may need to visit your local Apple retail store Genius bar or local Apple-authorized service center in order to have your iMac at least diagnosed to find out what the core issue is.
Regards,
-Mactechtrainer
Posted on Jan 31, 2010
Windows dose not load
Unfortunately, This Sounds Like A Problem With Your Hard Drive/ Logic Board. You Will Need To Go To The Apple Store And Get Your Laptop Fixed Or Repaired... If you Haven't Done So Already.
Aug 22, 2012 | Computers & Internet
Apple iMac g5 mac desktop stuck on white screen with apple no circle
Try two or three times, make sure there are no add ons usb
Mar 23, 2012 | Apple iMac G5 Desktop
When you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
The screen stays black when trying to start it. The little green light (icon) on the flip up portion of the laptop shows the slanted zee with the circle around it. The computer does nothing but turn the...
This is the IBM symbol for "it's not working."
You are not booting correctly and the computer is telling you so.
I'm thinking you could go into setup and restore the default (I can't remember right now how to get into the CMOS setup, but it might be pressing F2 or F12 or Del.
If you can get there and you have the choice of setting the default configuration, do that.
Otherwise you're looking at a hardware problem.
Dec 01, 2009 | IBM ThinkPad G40 2388 Notebook
My MacBook Pro goes to the grey screen with the
Most likely, you are looking at a corrupt installation of the OS, or a failing hard drive... most likely the latter, unfortunately. Laptop hard drives only seem to last a couple years now, 3-4 if you're really lucky. I would suggest popping in the System Restore Disc (that came with the computer originally) or the OS install disc (in case it has a new version installed than it came with originally) and go to Tools->Disk Utility, and tell it to "repair permissions" and "repair disk", and see if that resolves it. If it happens to, I suggest backing up your data ASAP just in case. More info can be found here on using Disk Utility.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
My iMac G4 turns on and goes to the grey startup screen with the apple and loading circle, but stays there, and gets stuck, and after a few minutes shuts off on it's own.
You may have to reinstall you OS e.g. tiger, leopard with the disks that came with your computer. that should solve your problem
Jul 18, 2009 | Apple iMac G4 Desktop
Will not start. Goes to a gray screen with apple on it then stops
You may need to boot from the MacOS X CD to do a repair. Insert the CD in the drive, and restart. Keep pressing the C key to boot from the CD, once the CD boots, you may have options to repair your MacOS installation, or alternatively reinstall the system software.
May 24, 2009 | Apple iBook G3 Mac Notebook
Message problem
That sign is GPRS go to network seting and stop GPRS
Feb 05, 2009 | Nokia 7373 Cellular Phone
Wont turn on
Start the computer and hold down the "C" key when you hear the start up chime. Keep holding down the key until the computer boots into the OS installer. You are going to have to reinstall the OS. Just follow the instructions from there.
Jun 25, 2008 | Apple MacBook Pro Notebook
Harddrive does not boot up to desktop
It is the hard drive. The EXACT same thing happened to me. You will need to replace the hard drive. You can backup all the info onto another computer using a firewire cable as I did. Boot your computer and hit "apple" "T" while booting, a firewire logo should appear and bounce around the screen. Makes your computer a giant external hard drive.
May 11, 2008 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
533 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
