Question about Maytag EPIC MFW9600S
I have a Maytag front load Mod. # MFW9600SQ1. When
I have a Maytag front load washer Mod. # MFW9600SQ1. When i run a heavy duty cycle with prewash.. rinse hold.. at about 1:24 to about 1:19 remaing i get F/H code. If i run the same cycle without clothes i don't get the code. I do see water coming in. What is the issue? Please help i urgently need to remedy this.
  • 65 Answers
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Posted on Jan 30, 2010
Testimonial: "It remedied the issue :) Thanks"
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Reset neptune
How can i reset my toshiba e studio120 photocopier machine?
Oct 22, 2013 | Maytag MAH6700AWW Neptune Front-Load...
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Nov 25, 2009 | Maytag Washing Machines
Washer won't drain
look for blockage in hoses and pump.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Maytag EPIC MFW9600S Logo
528 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
