Question about Samsung SyncMaster 205BW LCD Monitor
Samsun LCD Monitor power comes on screen blinks once power light (on button) goes off then comes on again. Cycle repeats
  • 644 Answers
It is possibility the tv's backlight or inverter board has failed. But the main problem could be blown caps on the power board.
To check for blown capacitors first unplug the set from the mains, and remove the back cover, there should be a few screws holding it together, once undone gently prise off the the back cover, Your looking for for the capacitors, they are barrel shaped componants with a silver top, check for any brown liquid readues on the board or the capacitors, if there are any they will need to be replaced, also look for any domed or pretruding tops they should be flat, if there are any they will need to replaced also.
To replace the caps you need soldering skills to desolder the faulty caps and resolder the new ones, ensure you get the correct value capacitors or they will blow again, on the side of the caps it should tell you there value i.e.16v 4.7uf "V" stands for voltage and "uf" stands for micro farrads, unsure that you get the correct value in micro farrads if you dont it wont work, the voltage is not as critical aslong as it is equal to or more than the stated voltage on the cap, more is somtimes better because it has more leway so if a cap is valued at 16v and you cant find one and you buy a 25v with the uf rating the same the less chance it will blow, if you buy a cap with a less rated voltage it will blow sraight away. Also make sure the polarity is right they will be on one side of the cap a couple of "-" minus signs to let you know which way around they go if you get it wrong the cap will blow, take a note of which way around they go before you desolder the old caps.
Hope this is some help.
Posted on Jan 30, 2010
  • Samsung Master
  • 5,568 Answers
Sounds much like a faulty switching power supply that is cycling. Most of these problems are caused by failing capacitors that must be replaced. The parts are cheap, even if better than original are used, labor is dependent on your area but will be much higher than the parts cost.
    Guru:
  • 829 Answers
It can be due to Resolution issue The graphic card is not set by OEM properly. Try to get newest drivers for graphic card or modify settings correctly.While the system is booting do you see any display , Also check the power cord cables and Display cables .Good Luck
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
May 18, 2009 | ViewSonic VX910 19" LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
L1902 19" lcd monitor power problem?
no stays completely blank. yes it is my pcs monitor
Oct 06, 2008 | HP L1902 19" LCD Monitor
Monitor goes blank after 5-10 minutes
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Samsung SyncMaster 205BW LCD Monitor Logo
498 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
