Question about Sony Dream Home Theater System, DAV-DZ120 System
When playing a DVD the dialog track is only a mumble. All the other sound is crisp. I've owned this system for about three years and this problem just occurred.
  • Sony Master
  • 19,396 Answers
Hi.
If all other functions are working , and the problem is not on a single DVD, then it may be a firmware issue.
Unfortunately firmware upgrade for this model is not available online.
In that case you will need to contact Sony at the number listed on product user manual, they will follow you through the procedure.
If the upgrade is not available, Sony usually replaces products that are defective because of factory problems even out of warranty time.
First ensure that the problem is the home theater player, and not a bad connection to the speakers.
Also ensure that the problem is happening on different DVDs, and it is not caused by a defective disk.
Before calling Sony, leave the unit disconnected for about ten minutes, to reset the circuits, and check all connections. If the problem is still there after this simple reset, contact Sony.
Posted on Jan 30, 2010
I have a LG BLU - RAY WIRELESS THEATER. model - BH6520TW. Somehow now when I watch movies the main talking and voices in the movie is sounding like it's playing in the background and sounds like it's...
check the sound setting on your remote or in the main menu section via using your remote _ it may be on a "hall" setting etc if all else fail use your remote and go to system and do a factory reset _ bit of a hassle but worth it all settings will be reset to default
May 27, 2014 | Televison & Video
The system plays the music but the voices are mumbled.
Look on the remote for "mode", "effect" and or the "sound edit" buttons. There are a few different sound effects to choose from.
Your manual:
http://downloadcenter.samsung.com/content/UM/200603/20060310100609484_Q70_XAA_ENG.pdf
Nov 03, 2013 | Samsung HT-Q70 Home Theater System System
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
DVD dialog track doesn't play
it sounds like your center channel or hookup is not working!
Dec 07, 2008 | Samsung DVD-V3650 DVD Player/VCR
Bose 123
Reset the system by unplugging the power cord and wait a minute before reconnecting power. The vocals will return. You should also contact Bose to see if your system needs a software update.
Oct 21, 2008 | Bose 3 2 1 GSX System
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Philips mcd288 mp3 albums
There's a little bit of work involved, but what you should do is to record those tracks individually as folders, then transfer those to your DVD burner...accordianman
Dec 30, 2007 | Philips DVD Micro Theater Shelf System...
No picture from dvd, but sound
What type of output are you using? Try using the component video output on the DVD player. (that's the one with three colors) This worked for me when the composit and s-video outputs stoped working.
Oct 12, 2007 | Coby DVD815 System
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
