Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman power mate not running when placed on run dies out...but runs on choke.
  • 714 Answers
RECOMENDATION:
-Remove soak and clean high-speed jet in Carburetor and clean float valve in Carburetor.
-Do not use fuel with ethanol.
-Use a fuel inhibitor with your fuel. this will keep the fuel from braking down.
-When your done running the Gen-Set for the season fill tank and treat it with a fuel stabiliser and turn off fuel valve and let the gen set run out of fuel. This will ensure that fuel is not going to evaporate in the carburetor.
Hope this tip helps.
R/
David
Posted on Jan 31, 2010
Coleman power mate won't start. Plug is good, fuel is getting to carb. If I use starter spray it will run for a few seconds and die.
sounds like a sticking float or clogged needle jet inside the carb.
i'm currently working on exactly that same issue
Dec 01, 2016 | Coleman Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
When chocked starts great and runs great, when you switch the lever to run it surges and dies
clean carburator i had same problem by running it on choke i only made the carb more cloged even though it seemed to run better clean the needle valve both holes now it runs like new
Oct 23, 2011 | Coleman Powermate Powermate 5000W...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Coleman Powermate Premium Plus 6250W Portable Generator Logo
159 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
