Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
F7 error message
The F7 error message flashes and the over beeps. We tried unplugging the over and then turing it on again, but it did not stop. Any suggestions?
  • 1 more comment
  • Anonymous Feb 19, 2008
    I have the same problem. It is VERY annoying though it does eventually stop. Not using oven because of problem.
    My stove is model svd48600, and its flashing the same code F7, Can any one help? Thanks Dave
  • Anonymous Mar 19, 2008
    F7 keeps coming up on display and beeping starts. After reset it comes back on over and over again. Can you help ?
    President:
  • Jenn-Air Master
  • 2,651 Answers
F7 is listed as being a stuck membrane switch for longer than 30 seconds, a button is failed and is stuck in. replacemnet is on ly fix you cant repair active overlay switches
Posted on Feb 23, 2008
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Beeping & flashing F7
It means one of the keys is stuck or shorted. Shorted Clear/Off Key
due to membrane switch,
Control or connector
May 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
OVEN BEEPS FLASHING -F7- IN CLOCK WINDOW
F7 indicate that the EOC (electronic oven controller) will need replacing. Parts are available at http://www.repairclinic.com/
Thank you for using Fix Ya
Please take the time to rate this solution.
Feb 03, 2009 | Maytag MER5755QAS CleanDesign Electric...
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Jul 25, 2008 | DCS WO-130 Stainless Steel Electric Single...
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
1,192 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
