Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead:
https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Can't remember my code to my sentry safe that has a key pad
Lost code to my sentry safe that requires a 5 digit code on a Digital key pad
quel est le code manufacture du safe sentry dsw3607
need to know how to reset the code
Changed batterys now code wont work cant open safe
I have lost my5Digit code from the factory cannot change my combination on my safe what can I do
