Question about Sony Ericsson W200i Cellular Phone
How to remove a answer phone message - Sony Ericsson W200i Cellular Phone
Go to general in settings and then press voie commands then press deactivate all
Posted on Feb 01, 2010
Phone is stuck with New Message when there is none.
Unlpug answer machine from power source. Remove battery from handset (and also the answer machine if it uses a battery backup). Wait about 15 minutes, then reconnect everything. Message should be gone, or you should be able to clear it if it's still there. If that doesn't work, then you may have a bad circuit board in the answer machine. (Ps... Make sure you don't have a "save" feature for old messages. They will always remain, even when the display is "zero").
Oct 16, 2015 | Siemens Gigaset A265 Cordless Phone
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Message lite staying on after all message are removed
When you say "all messages" are you referring only to the messages on your answering machine or are you including the messages on the voicemail system provided by your telephone company? This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Oct 16, 2013 | AT&T DECT 6.0 Cordless Phone System with...
I get a message saying "Out of Range", how do I
Usually the quickest way is to remove the battery from the device for 30 seconds and then reinsert. That will force the phone to scan what channel your base station is on and connect to the right channel.
Mar 03, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I have Comcast on my phone & have had the phone answering taken off from them, however, I cannot put a message on my GE phone answering system. The "phone lady" answers saying we are unavailable at...
The phone lady thats answering the line,it that message through comcast or the GE answering machine? Also, whats the model number of the GE answering system?
Jun 09, 2010 | GE Lands Phones
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Message light flashing
this is a callback message it is activated by pressing the message key while the called party is ringing. To remove it you must answer a call between the two.
Nov 18, 2008 | Mitel 5220 IP Phone
Trying to reset "message number" back to 00
that is the number of messages you have on your machine. If you don't like having messages, then you can delete them by pressing and holding the Play/pause button (blue button below the red answering machine light) until messages start to play. once they do, hit the remove button for each message you want to remove. Kepeech?
if you don't like having a message number higher than zero, then you probably shouldn't have an answering machine! :)
May 19, 2008 | AT&T 1855 Phone
Cannot record new answer phone message
push the mute button on your cordless uniden phone,and you will see the number 5 come up on the phone display.then hit the number 6 and when you hear it begin to beep record your message
Mar 13, 2008 | Lands Phones
Sony Ericsson W200i Cellular Phone Logo
44 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
