Question about HP LaserJet 1320 Printer
Left side of paper is not printing well - HP LaserJet 1320 Printer
    Master:
  • HP Master
  • 406 Answers
Shake the toner catridge and replace, if it persists drum or roller might be damaged.
Posted on Feb 04, 2010
Print on left side of paper lighter than right side
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
May 02, 2013 | Dell 1320c Laser Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
Printing
It almost sounds as if the guide on the left side has been moved. Reload the paper so it is up against the right side of the paper tray and then move the left guide up against the paper.
Judy F.
Aug 28, 2008 | HP DeskJet 6122 InkJet Printer
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
HP LaserJet 1320 Printer Logo
Seeker5211
Seeker5211
