Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
My printer is pulling the paper only from the right side and then its giving me error 3 as if ther was no paper.
    Sergeant:
  • 284 Answers
Error 3 is Paper Jam error code. Maybe there are some paper still stuck inside. Or else you may need to replace the DRIVE ASSY http://www.comcentre.com.my/mbc/prod_list_view.php?prod_id=284&pageNum_Recordset1=0&xsearch=
Posted on May 31, 2010
Every time I try to print something, the paper doesn't pull from the tray straight. It pulls to the left side and crumples the sheet of paper so that it can't feed through the printer.
You do not state the type of printer so it is difficult to give exact instructions, but I know what your problem is. Something is stuck in the paper path on the right hand side, hence the reason is skews to the left because the left side is able to advance and the right is hitting the obstacle. If your printer has a paper drawer, turn off the power, remove all cords and the cartridge. Pull out the paper drawer and then carefully stand the printer on it's back so that you can see where the paper goes as it comes out of the tray. You will likely find your problem right there. If you can repost with an actual model I can give you a much better idea of how to find a paper jam but these instructions should help you.
Mar 26, 2011 | Office Equipment & Supplies
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
When printing, the paper gets pulled slightly to one side (to the right when facing the printer) and ends up not being fed through.
i used samsung laser printer now toner exhuastet show error and red led glowing.Please help and give the solution
Mar 05, 2010 | Epson Stylus Photo R220 InkJet Printer
Canon ir-400 error load paper when i give data print
More than likely your computer's setup for where it is to pull the paper from has designated the manual bypass tray (the flap on the side of the right side of the copier that holds paper) as it's main source. Go into the control panel/printersandfaxes/ and look under the profile tab of your copier. Good luck
Dec 09, 2009 | Canon Office Equipment & Supplies
Printer won't feed paper
The unit does not power on.
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
General
errors
Oct 09, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Cannon mp210
Thers a sensor on the right hand side of the printer uder the metal bar. You will find that the actuator arm is up causing it to be on causing an E3 error. If you carefully push a flexable ruler from the top you can usually dislodge any foreign objects in the paper feed dont try to get it from the front you ll break the sensor arm rendering your printer useless
Aug 01, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
