Heil 5000 blowing no heat. cant get pilot lit.
  • 334 Answers
After making sure you have gas to the unit. Replace the flame sensor. The pilot should stay lit then.
If the unit does not sense flame, it stops sending gas to the pilot and will not operate. Flame sensors go bad regularly. You may get lucky and find that cleaning the sensor works for a while.
Posted on Jan 31, 2010
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Pilot on my gas furnace won't stay lit
Try cleaning the thermocouple tip if you can see ashes or any buildup on it. If you know the wind isn't blowing it out (had mine blow out from high winds before) then I would change the thermocouple before anything else.
Dec 09, 2013 | Heating & Cooling
Have a Heil Quaker NUGK080AG02 80,000BTU Furnace w/serial # NUGK 080AG02. The Ignitor lights the pilot but then fails to cut out (shut off etc.) once the pilot has been lit. What is the most likely...
Probably your flue isn't clear enough.
Try blowing it out, you might have to remove a cover to do it.
Otherwise it may be the flue passage detector needs replacing.
Nov 18, 2013 | Computers & Internet
The pilot light on my heil quaker furnace won't stay lit. I replaced the thermocouple (man was that a task, between the design of the furnace, and its placement in my attic) but that didn't change...
Make sure the thermocouple is clearly in the heart of the flame. Make sure the thermocouple is securely and properly connected to the gas valve. Obviously make sure it is the correct thermocouple. Gas valves do go bad, so it could be that but that is fairly rare. Good luck.
Apr 30, 2017 | Fasco Furnace Draft Inducer Heil Quaker...
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
Williams wall heater
It can be shut off, but do not just blow it out.
Mar 02, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Pliot is lit...no heat
check to see if voltage to gas valve if no replace or check wires
Jan 06, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
I have a Ruud deluxe 80 plus heater. The unit is running, the pilot light is lit, still no heat.
repost with more specific . motor aka fan is running?stat is set to heat and max heat? how old? general progression is as follows. stat says its cold. signal is sent to gas valve to open. gas valve looks to see if pilot is lit via thermocouple. if pilot is lit then main valve opens and burner lights. shortly thereafter sufficient heat builds up to trip heat sensor that turns on fan and blows hot air into house.many times a tripped safty causes a default fan response. aka when you show up the fan is on 24 7 . that equals a failed safety and needs a pro tech to see why saftyfailed.
Oct 18, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
211 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
