Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Mld pro-suite I get a message when starting my computer, ?nable to locate control center 2.0. Re-install MFL Pro-Suite...how do I do this?
  • 832 Answers
By deinstalling the whole mfl-pro suite.
There is an update avaiable for control center.
plz see here: www.brother.com  (choose your country and then your mfc)
Posted on Feb 18, 2008
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: mld pro-suite
sounds like you're due for a new set of drivers get em here
and btw, you're my 1,111th solution, so send me a note through contact information on my profile, for a complementary tuneup
Posted on Mar 05, 2008
Mix-it-up
  • 832 Answers
simply by puting in the brother cd and click the repair buitton. btw: there is a update avaiable. see brother homepage of your country.
Posted on Mar 17, 2008
How di I reinstall PaperPort Print Driver? PaperPort 11, Windows 7
Instructions extracted from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
"{Ok, here is how I got the whole package from my Brother MFC and PaperPort 11 with the printer utility.
First if you have tried to install the suite or paperport and are having issues uninstalling through windows download this wonderful program that removes everything called Revo Uninstaller at www.revouninstaller.com and choose the freeware version.
Now go to the Brother website and search for the Windows 7 MFLPRO Suite and you should download a zip file that contains the suite for multiple MFC’s. Unzip it and set it aside. This is only the Brother Suite for the Brother MFC and the Control Center 3.
TO find the Windows 7 version of MFL PRO go here
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=5
PaperPort 11 will have to be installed from the actual CD that came with your printer. Inside the CD with Windows Explorer File System locate the file Inst32.exe that should be inside the CD under the install folder then MFC-465CN (my model) then usa folder. Remember the location.
Now set everything aside and let’s start. Open up control panel, click on programs and features then choose Run programs made for previous versions of Windows. You have just opened up program commutability, now click next and wait now choose not listed and press next. Browse and fine the Inst32.exe file that I mentioned earlier. Now click next and then choose Try Recommended Settings, Next your setting should say applied and compatible with Windows XP SP2, then you will see a tab on the next screen that says Start the program. Click on it and allow it to start installing this will start the suite and the first thing that installs is PaprPort, be patient let it continue to run and after it will install the PaoperPort print driver, then after it will start into the MFL PRO Suite. This is where my installation halted because the suite is a 32Bit version it would not continue. I looked and PaperPort program and printer where installed. Close it up and pres next.
Finally now you can install the MFL PRO for Windows 7. Open up the folder you downloaded from Brother and look for your model and you will see the setup.exe application, click on it and start installing MFL PRO along with Control Center 3. That’s it, and your setup should be complete.}"
Hope the thread from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
will help.
Jul 21, 2010 | ScanSoft Nuance PaperPort 11 for PC
The error "CC025" appears [DCP-115C]
first uninstall the MFL Pro Suite & all the componants, shut down and restart system fresh install MFL Pro Suite fro the original CD supplied.
Jul 02, 2009 | Office Equipment & Supplies
Control Center2 will not start - Error cc025
Had the same problem. The solution was: - uninstall the brother software with the application in the brother folder restart PC - reinstall mfl-pro Suite restart pc - install update to Controlcenter2 - install updated drivers
It then worked and I could finally scan over the network, for the first time ever!
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
Printer Drive Problem
Please uninstall all drivers and software related to printer. Detach printer from computer connection.
Install drivers and software without the printer connected.
Restart computer and connect printer.
Thanks and Good Luck! =)
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Since the printer is working the drivers are installed correctly. The drivers help the computer recognize and operate your printer. The error that you are recieving is from the program called MFL Pro Suite. If you still have the CD you can reinstall the software and this error should go away. If you found solution this helpful please rate it.
Thanks - Tech101
Jun 23, 2008 | Computers & Internet
Mld pro-suite
Mar 16, 2008 | Brother DCP 130C All-In-One InkJet Printer
Mld pro-suite
Mar 04, 2008 | Brother MFC-7220 All-In-One Laser Printer
MFC 440cn, lost mfl pro suite
The advice given so far is not entirely accurate.
On the Brother Wesbsite:
Select the downloads link.
When searching for your download
Step 1:
make sure you have "ALL" selected
Step 2 and 3 are self explanatory
Hit the search button and then you are looking for the download that says "full software and driver package".
Install as directed.
Feb 16, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-665CW
download the uninstall drivers from brother homepage of your country. Run the uninstall routine, reboot pc and uninstall the rest of the mfl-pro suite. After rebooting pc install the suite again. (hope you didnt connect the printers first, when installing the suite! Printer has to be connected when software demands the printer!)
BTW there is an update avaiable for the CC3 version (see brother homepage).
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
348 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
