Question about Hotpoint Dryers
Heating problem with Dryer Ariston ASL 70C
I got a problem with Ariston dryer ASL70C.
The drier does not heat. I remember I had the same problem in the past when the cloths were too wet and the drier kicked a heating switch off.
Techncian came and just turned the switch back on.
I trie to open the back of the drier where I remember the echnician found the switch but I could not find.
Can you help?
Hi.
in top of the heater box there is a thermoswits back of this swicth there is a tiny little hole use a paperclip or similar an put it to the hole and press not to much until you hear a little click and the thermoswicth is reset. and your dryer can heat again:-) and DONT forget unplug the power to the dryer first.....
best regards
ls danemark.
Posted on Jan 06, 2011
  • Rene Kristensen
    Rene Kristensen Nov 04, 2011
    Hey are u from Denmark'? Need help please
Drier not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././,';
May 02, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
I have an ASL70C Ariston tumble drier that suddenly has stopped emptying the water into the water tray.the clothes are still drying but where is the water going
Einy Lane -- Water Drain question -- If your dryer is installed next to a drain the water can be plumbed into this drain. This does away with the need to empty the water container. Simply remove the top hose from its top fitting at the rear of the dryer and plumb the hose provided to the drain.
If a leak has developed in absence of using the drain hose feature, then the water is going someplace else. Unplug unit and then check behind it for the drain line being fallen down. If you need more help, please write back. User Manual can be downloaded without charge from Hotpoint website. -- SWT
Aug 04, 2010 | Dryers
Power going to dryer you can hear a noise when pressing start but not starting
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 21, 2010 | Hotpoint Ariston ASL 75 CXS NA Electric...
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
I have a whirlpool dryer and it heats up but dosent dry clothes
you have a blockage in the vent system. If the clothing is hot and wet when you remove them then there is a lint blockage either at the lint trap in the machine or at the exhaust hose on the back of the drier
Dave
Mar 17, 2010 | Dryers
Drum turns and you feel some heat but does not dry clothes
check to make sure you have no lint buildup in the drier itself along with lint build up in the exhaust hose leading from the back of the drier. If there isn't proper exhaust from the lint filter to the outside of the house or apt. then the clothes will get hot but still be wet.
Hope this helped
Dave
Mar 02, 2010 | Frigidaire GLER331A Electric Dryer
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
791 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
