Question about Vacuums
Brush will not turn around, it runs but not the second speed with the roller brush. i cannot figure out how to rmove bottom
  • 701 Answers
Ya you need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Jan 31, 2010
I changed the roller brush on my Oreck XL Insight vacuum and now when I turn it on it only runs for about 5 seconds and shuts down Any ideas
Bigme03,
It sounds like you may have been given the wrong brush roller. Several models of Oreck's have a sensor in them that watches for the brush roller turning at the proper speed. The way they do this is by mounting a magnet into the brush roller and the sensor counts the number of times the magnet passes. If that magnet is not there or if the sensor does not detect the magnet passing, ie..a broken belt, it will shut the motor off. The only way you can fix it is to get the correct brush roller and put it back in. Hope this helps!
Mar 07, 2015 | Oreck XL Insight Upright Vacuum
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
Our brush doesn't rotate anymore on our U5402-900 vacuum cleaner. What are common causes of this?
The number one cause of brushes not rotating is a broken belt. If you remove the four screws holding the bottom plate, you'll see a short, wide rubber belt that goes around the roller.
The number two cause of brushes not rotating is, as suggested above, something jammed & wound around the roller. It's always a good idea to turn the vacuum over periodically and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Hoover Vacuums
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Installing roller brush for oreck XL 21
uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
Jun 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
May 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Rotating bruch
take off the bottom cover where the roller brush is a few screws should be all it takes underneath cover should be roller and belt if belt is broke replace it lift up roller there is a slot for the belt to run in put other end should be the motor side put belt around pulley bar put it back the same way it came off.
hope this helps
Dec 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuum Roller making a loud noise
Your roller brush is starting to fail. If you unscrew the ends, you will find a lot of hair wound around the stem. You probably have a warped plastic end the holds the bearing. This is my problem now.... I am looking for a new roller brush as I write this. I found one for $30. Good Luck.
May 11, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
