Question about Maytag MAT12CS Top Load Washer
Filling Machine When filling Machine ,water run's in to slow.
  • 1 more comment
  • Borris Feb 18, 2008
    Sorry, my fault. The machine is brand new,has never been used.
    It might be a plumbing problem ?
    Thank you, Borris.
  • Borris Feb 19, 2008
    I do thank you for trying, and I did say thank you posted on the 18th Feb.
  • Anonymous Oct 25, 2008
    Water fill up at the start was fine but recently takes forever! Screens are clear. Could it be the inlet valve on the washer?
  • 164 Answers
Check the hose screens. the could be clogged. also there are screen in the inlet (water valve) that also might have gotten full of crud.
Posted on Feb 18, 2008
  • Geoff Siegel
    Geoff Siegel Feb 19, 2008
    How can you rate this as inappropriate when you didn't give enough information to solve your problem. based on your info i gave you my best possible solution. at worst you should have rated me thanks for trying.
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Very slow filling of cold water. Hoover 5 Kg
heatman101
May 23, 2011 | Hoover Washing Machines
Slow filling Model lw4303wi
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Apr 15, 2011 | Amana Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
heatman101
Mar 30, 2011 | Washing Machines
Slow filling
heatman101
Nov 19, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Why wont the washer start filling ?
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Maytag MAT12CS Top Load Washer Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
