Question about Windchaser Dehumidifiers
I have an air exchanger (honeywell) that is broken. My HVAC guy recommended a Venmar. I presently have the broken air exchanger in the basement hooked up with a dehumidifier. What product should I buy? Is it proper to have a dehumifier hooked up with an air exchange system?
  • 2 more comments
  • pquin1 Jan 30, 2010
    I presently have a dehumidifier hooked up with the broken Air exchange. I know that Venmar sells products that have a built in system to remove humidity or add it during the winter months. The system now installed has fresh air coming into the air exchange and comes out the port and is vented to a "t" duct that has the air going into the house and also into the dehumidifier. the fresh air in the dehumidier is then vented to the air exchange with stale air from the house(another T duct). There is a separate vent leading outdoors from the air excahnge. Is it normal to have the stale air and fresh air from the dehumifier going through the air exchange. It seems to me you are defeating the purpose of a dehumider if the stale air (with moisture) is vented to the air exchange and half of it is sent back to the house essentially bypassing the dehumidifier. Is this system set up right? If I buy a venmar, do I utilized my dehumidifier or not? The way it is set up, does not make much sense to me. Can you advise?
  • pquin1 Jan 31, 2010
    Thank you for your response. I understand how a air exchange works now. How do you set up a dehumidifier with the air exhcanger properly. thanx Pat
    how is the hookup utilized when you use a air exchange with a dehumidifier?
    I need to know more information
  • 10,515 Answers
Bingo!! That is one of the Best Air Exchangers other than Honeywell which is Quite a Good Product too.
It is Important that you should have a Better Air Exchange System.Read below, that would give you a better Picture of Importance of Air Exchange System :-
http://www.airdetectives.ca/air_exchangers.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
  • taran_2005
    taran_2005 Jan 30, 2010
    Thanks for your response!!
    Let me try to Explain How it works :-
    1. Stale air from the house is drawn to
    the unit, and transfers its heat to the
    fresh incoming air.
    2. A portion of the stale air is exhausted
    to the outside.
    3. Fresh air from outside is blended
    with interior air. Then, the airflow goes
    through the prefilter (catching the bigger
    particles).
    4. Fresh filtered air is distributed
    throughout the house.
    Even if you Purchase Venmar, that would use Dehumidifier. The Functionality is more Complex than it seems like :)
    Hope i helped you.
    Thanks
Unit comes on briefly then kicks out bucket without getting any water out of the air. Basement is very wet
Hello friend, I appreciate your post!
From my understanding your Frigidaire dehumidifier is shutting off and on without removing any moisture from the air. I would recommend trying a different outlet within your basement and adjusting the setting to see if that would help. Additionally, try to turn the unit on continuous drain to see if it pulls any moisture out of the air. If your appliance continues to shut on and off I would reach out to the manufacturer to see if they could assist with any additional resolution. Hope this information proves helpful. -Matt
Aug 24, 2014 | Dehumidifiers
How do I repair the cooling system?
Well I signed up for HVAC classes at the community college and that worked out well for me. Repairing your own system is a great reason to go to HVAC school, but it will probably cost more than replacing the unit you mention.
Jul 03, 2014 | Soleus Air SG-PAC-08E3 8,000 BTU -...
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
I have an lg dehumidifier model # LHD65EBLY8. The bucket is full light keeps coming on even though it is empty. Because of this, it will not stay on and my basement keeps flooding. Do you have any...
booklover, if the the bucket is not properly installed, the unit will not turn ON. If you remove the bucket and look at the left top corner it, you will see a float device arm. It that's stuck in the UP position, jiggle the handle, so it will return to the DOWN position. In addition, that handle must make contact with the bucket removal safety switch, if not the bucket is improperly installed and the unit will not start.
Since you are using this unit in a basement, I highly recommend that you raise the unit up off the floor onto a sturdy table, counter top, etc. that can handle the weight if the unit, plus a full bucket of water. As the air temperature at floor level is colder than at chest level. The coils on your model will start to freeze at 60 degrees F and affect it efficiency, Because it is not a Low Temperature model designed for basement applications.
In addition to the dehumidifier, you would be wise to install a sump pump, if your basement floods as bad as you made it sound. Combining a sump pump with a dehumidifier will guarantee a dry basement, all the time.
Hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | LG Dehumidifiers
My dehumidifier suddenly does not remove any water from the air. It worked perfectly last summer and just sat in the basement unplugged over the winter. I plugged it in a few days ago and it has been...
It may simply be a case that the air intake filter needs cleaning, as do the condenser coils. This is recommended maintenance, prior to using the dehumidifier for the first time each season. Also, the air temperature at floor level, may be to cool for it operate properly. Particularly, if it's below 60 degrees. the unit up off the floor and placing it on something sturdy, will help solve that issue.
After cleaning the unit, as stated above, try placing it upstairs where the temperature will be warmer and allow it to run at it's lowest humidity extraction level. That's usually 35%. If it functions properly upstairs, then you will know that it's an air temperature issue in the basement.
Hope this helped you troubleshoot and solve the problem.
May 26, 2011 | Whirlpool AD70USS Dehumidifier
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose.
You need an AC outlet of a central AC in your basement, or a window unit if there are windows.
Warm air at discharge is normal.
Sep 04, 2017 | LG LD40E Dehumidifier
Dehumidifier coil frost up
Hi Eric where do you live? what is the Air on temperature i the basement? what is the Air off temp in the Basement? what temp difference are you getting.I ask where you are located in the world so we can work out the Ambient temperatures in the area.
Jun 08, 2009 | Whirlpool 75-Pint Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Heats up basement
Dehumidifiers and how they work
Heat pump dehumidifiers
Dehumidifiers use a heat pump (similar to an air conditioner's heat pump) or chemical adsorbents to remove moisture from the air without cooling the air.
A heat pump dehumidifier uses a fan to draw indoor air over a heat exchange coil. The coil is almost freezing. The water in the air condenses on the coil and is drained. A second heat exchange coil reheats the air, which the dehumidifier exhausts into the room.
A heat pump dehumidifier dumps heat lost from the compressor and fan motors into the air. It returns to the indoor air the heat generated by the dehumidifier turning water vapour to liquid. I got this off the internet
Jun 24, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
77 people viewed this question
Top Windchaser Dehumidifiers Experts
Steve
jasbo
jasbo
john h
Are you a Windchaser Dehumidifier Expert? Answer questions, earn points and help others
