Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
How do i clean the rennai - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
  • 1,420 Answers
Remove the filter(S) on the top trim panel off. Vacuum the rear of the heater. Also vacuum the side panels where the return air enters in the back of the heater. You can also remove the front main panel and lightly vacuum the area to the right of the heat exchanger. You are done!
Posted on Jan 30, 2010
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
Rinnai 2520 problem
yes but do not think you will find the solution here and not sure you would be able to accomplish this either
I would contact the mfg of both pieces and as well look for DIY sites that may be of some help and more detailed
It would take a l t of time to walk you thru this
This being more of a it is broke I need to fix it not modify website I would not attempt to do here
Be cautious taking help on the net just because it sounds right does not mean it is
Oct 18, 2013 | Water Heaters
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
My rennai convector 417 makes clicking noise but wont ignite
check spark is jumping a gap across the gas flow check thermocouple
May 24, 2011 | Cozy (VCR502A-BM) Heater
Rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Aug 12, 2009 | Heating & Cooling
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
87 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
