Sewing Machines Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My machine numbers are 6268m82045024. I have lost manual. could I down a new manual? I can,t figure out how to make a buttonhole
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Jan 30, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150318
Points
26471
Hi
Thanks for using FixYa. You can buy it online from the link---
Singer Sewing Machine 6268 Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
JANOME NEW HOME MY EXCEL 18W / MW3018 FREE ARM SEWING MACHINE -
Here are the steps to sew a buttonhole on the Janome New Home My Excel 18W/MW3018 sewing machine:
  1. Attach the buttonhole foot to the machine.
  2. Place the button in the back of the buttonhole foot and adjust the foot so that the button fits snugly.
  3. Select the buttonhole stitch on the machine. It may be a buttonhole symbol or a number corresponding to the buttonhole stitch.
  4. Set the stitch length to the desired length for the buttonhole. The machine may have preset lengths or you can adjust it manually.
  5. Place the fabric under the foot and lower the foot.
  6. Sew the first side of the buttonhole. Stop the machine when it reaches the end of the buttonhole.
  7. Sew the second side of the buttonhole, stopping at the end.
  8. Use a seam ripper or scissors to open the buttonhole carefully.
  9. Remove the fabric from the machine and trim any loose threads.
Make sure to practice on a scrap piece of fabric before sewing the buttonhole on your project.
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
2helpful
2answers
My buttonhole is not working I hear a beep when i press down on the foot to go, what am I doing wrong
I get the same beeping when I forget to pull down the buttonhole lever
if you have the automatic buttonhole & the buttonhole foot that you have to put a button in,,check & see if there is a buttonhole lever that has to be pulled down, it will be a lever to the left of the needle bar
2helpful
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
2helpful
2answers
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
3helpful
I am trying to use automatic button hole and it keeps beeping and showin bl?
Ok, so all the credit goes to this website http://www.burdastyle.com/howtos/show/95
Photo 7 shows a buttonhole lever that comes down and contacts the auto buttonhole presser foot. The machine manual is a little vague about this in the section about buttonholes. At the point when it shows the lever being pulled down, the manual should reference the part number in the list of part names in section 1, and it would have been easier for me not to have mistaken that lever with the stop on the side of the presser foot that the lever sits against . . . . that also kinda looks like a lever! Probably a no-brainer for someone who does this all the time, but for a noobie like me . . . .I'm glad I found the website above. So . . . .the machine is now making perfect buttonholes 30 seconds after finding the butonhole lever! Groovy!
John and Linda
Buttonhole lever pulled down (presser foot not attached)
e011ff3.jpg Buttonhole lever resting against stop on presser foot
(Photos from burdastyle.com)
3helpful
3answers
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
