Question about Hitachi 53UDX10B 53" Rear Projection Television
How do you aline tubes - Hitachi 53UDX10B 53" Rear Projection Television
  • Hitachi Master
  • 3,459 Answers
You can see some examples and find a fix here...
how do you aline tubes - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 03, 2010
How to do an alignment on a 2003 caravan
Jonah is correct on his advice. Wheel alignment is not a DIY type of thing that you can do at home.
Oct 17, 2011 | 2003 Dodge Caravan
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
Front left wheel not touching the ground on JEEP PUSHCHAIR
The frame has a bit of a twist in it. The Aluminum tubing can be bent back into alinement by your average hubby. I use a collection of larger diameter pipes as levers to help reshape a frame but more often than not just a bit of brute force does the job.
Nov 17, 2010 | Baby Gear
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Mitsubishi VS-6041 focus issue
Try adjusting the sharpness in your TV's menu. If it's not just that, then perhaps the tube/LCD display is simply degrading.
Jun 03, 2010 | Mitsubishi VS-6041 60" Rear Projection...
Not printing. Will not take in the printing paper. Information window tells me to aline the ink cartrage. I have replaced new ink cartrages. Somthing is trying to turn as it is making a ratchet noise. ...
yes you have to print out a alinement sheet then put it in the scanner and scan then follow the directions to aline the print cartrigde once it is alined you ready to go. and you have to do this each time you replace the cartridges.
Oct 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
Color is gone
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
