Question about Euro-Pro Steam Generator EP8001 Iron
Can you mail me or let me know where to get the how to use for this steamer it was giving to me with no instructions /how to fill it? did not find a list for this product it is as read on product: professional portable steamer euro pro select
  • 10,515 Answers
Kindly mention the Model Number so that i could try to Find out the Instruction's Guide.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
Hi floyd, a friend of nime gave me a steamer and i dont know how to work it i dont know see where you put the water in at.i need to know step by step instrutions on how to work it.
what brand? what does it look like? should be a heavy screw-on cap on water tank. Fill with soft or distilled water, power on, and should be a red light that comes on when hot enough for steam
May 14, 2012 | Rowenta Commercial Garment Steamer - White
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Rowenta Steamer
Same thing with my daughter's..any solution out there?
Jun 22, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Wonder Steamer
Have lost the cord & instruction booklet for the Wonder Steamer.. Can you help?
Feb 20, 2008 | As Seen On TV Wonder Steamer Kit Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
110 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
