Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My Kenmore Heavy Duty Washer Series 90 does not spin the water out of heavy rugs and blankets well enough. What does it need?
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore/Ultra Fabric Care IV - Heavy
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
Sep 15, 2009 | Washing Machines
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washer works but smells like its burning.kenmore 90 series heavy
The burning smell could be the motor going out. When the water gets into the tub and makes it heavy it puts strain on the motor and the motor may be getting weak.
Feb 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
