Question about RCA L26HD35D TV
How can I receive local channels on this tv? I do not subscribe to cable and only want local tv channels. I purchased antenna, but no luck. I only get ION channels
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
all you need is an antenna then run the auto scan programming to lock in any available channels.
I roof or attic antenna would work better than an indoor antenna
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Jan 30, 2010
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
My new HCT LCD TV is not getting my local channels
if your tv is hooked up with cable program as a source their might be problem with the cable provider try to contact for assistance.now if you just only using the areal antenna as a source try re orient first the proper position of the antenna to receive local channel. channel scan much better also either the manual search or through auto channel search . good luck hope this may help.
Jul 21, 2011 | Televison & Video
I only get 12 channels. . .why?
Download the user's guide and go to page # 19 for more info on how to set up the TV to the proper input to receive all the channels.
Let me know if you need further assistance.
Jun 12, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Do i need just an antenna or one of those digital converter boxes to get just local channels in Denver on this TV?
If your TV was made after 2007 it should have the digital receiver built in. If so you can just hook any antenna you wish up and receive all your local channels.
Jan 15, 2010 | Sony KV-35S42 35" TV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Jun 22, 2009 | Initial Televison & Video
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Television only locates 7 channels????!!!!!
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Mar 07, 2008 | RCA F32649 32" TV
RCA L26HD35D TV Logo
198 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
