Question about HEALTHRIDER S200 TREADMILL Drive Motor
Healthrider Treadmill error code PO
Does anyone know what part is bad when you get error code PO on Healthrider treadmill? This is an older (10yrs) model - HCTL24570
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Posted on Apr 15, 2010
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
Soft strider by healthrider tread mill does not function and the error code PO comes up any suggestions?
1) Please exchange batterires for a new ones.
2) Tight the flexible cables from keypane vs display board.
3)Tight the connector from display board vs lower board(Main motor board)
4)Adjust the reed sensor switch by 1/8" or 3mmsSee the diagram attached.
5)Measure input voltage for 115 Vac to input of main motor board
6) Measure input for power supply for +5VDC to main motor board.
7)Measure output voltage for +5vdc to Display board.
8) Finally see the block diagram that I am attached that I did for people like you. For easy diagnostic and troubleshooting.
Sincerely. Merry Christmas.
Ernesto CuaddraManagua, Nicaragua.12_24_2011_4_58_14_pm.gif12_24_2011_4_58_29_pm.gif
Dec 23, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Treadmill wont work
Error Code: Grade potentiometer out of range (PO error)
Meaning: error detected in the elevation system you need to recalibrate the elevation potentiometer You can find a qualified technician or send me an email to cardiotech_me@hotmail.com to explain the steps.
Jul 05, 2010 | Landice L 7 Club Cardio Trainer Treadmill
HEALTHRIDER S200 TREADMILL Drive Motor Logo
473 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
