I find that I have an available network with a good signal, however my system will not connect.
    Sergeant:
  • 226 Answers
Hi, unless it is your network, you should not be connecting to it.
But the reason you can't is because you can see it doesn't mean you can connect to it because of the security, unless you know the WPA Passphrase key you cannot connect.
Now if it is your own network you will have to log on to your router to find out and alter any settings yourself.
But if you are trying to hack into a network, it is very illegal and could/will land you in a lot of trouble if you were caught.
You wouldn't like it if someone connected to your network and decided to use your internet and may be even watch what you were buying and steal your credit card details
But at the end of the day don't worry if you can see another network, all it means is that there router is broadcasting there name, which can be turned off in the router settings.
If it is to connect to your network, i will gladly help you out.
Sorry to go on.
Regards - Anthony
Posted on Jan 30, 2010
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Hi guru, i wish you help me please!! i condigured my wireless router actiontec and i have internet acces in my pc by cable ethernet, but when i try on my laptop by wi-fi or with my celphone, it says that...
Ethernet gives network signals from computer server with connectivity capacities. Once the ethernet is connected to your computer, once of the computers within the network structure has a modem or signal converter box to capture and distibute signals. Your computer is functioning with ethernet cable connection as arranged default. Recent computers however have wiifii capacities meaning that, the modem box is not ncecssary to make signals recognised. Recent computers have builtin signal recepticles, once the programs wireless features are enbled, any available computer networks aer detected. Howver, the wiifii makes connectivity to networks by requesting password keys if the aletrnate computers have protected the entry. Simply said, your computer is ok to function with ethernet as regular achievement. only when the ethernet is malfunct usually caused by the computer that has the modem disconnecting from yours. Your computer should actually get better networking with only one of the method available either ethernet or wiifii. Attempting to receive signals with wiifii and ethernet at the same time impedes the network speed since the structures may only allow an amount of data passage for each network on the same computer. Use the computer wireless buttons located at the system settings area to disable the wiifii until a computer request within your knownlege request to activate wiiffii. Keep in mind that once your wiifii is enabled, another computer is sharing resoruces makign the computer slower if a password was not set.
Feb 04, 2011 | Computers & Internet
Im having trouble connecting to internet with aspire one acer wireless net connection status: limited or no connectivity, but shows 54.00 mbps and a strong signal strength, how can i fix this
Is this happening when connecting to your home network or at public wifi sites? Check the network connection icon in the lower right hand part of your screen (called the system tray), right click on that, and it should have a popup that says "connect to a network" click on that, and a list of available networks should be listed. Many public wifi sites are security protected, so make sure you have the appropriate user name and password for the site you're using. If the site is listed, left click on that to highlight it, then click connect at the bottom of the window. That should establish a connection with a local network. If problems persist, download and install a new copy of the network driver software (available from the manufacturer). Good luck!
Dec 22, 2010 | Acer Aspire One PC Notebook
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
2002 Cadillac ignition turn
  • A network is a group of computers (often called nodes or hosts) that can share information through their interconnections. A network is made up of the following components:
    Computer systems (nodes or hosts)
    Transmission media--a path for electrical signals between devices
    Network interfaces--devices that send and receive electrical signals
    Protocols--rules or standards that describe how hosts communicate and exchange data
    Despite the costs of implementation and maintenance, networks actually save organizations money by allowing them to:
    Consolidate (centralize) data storage
    Share peripheral devices like printers
    Increase internal and external communications
    Increase productivity and collaboration
    There are several ways to classify networks. The following table lists several ways to describe a network.
    Peer-to-Peer In a peer to peer network, the hosts provide and consume network services, and each host has the same operating system. Advantages of peer to peer networks include:
    Easy implementation
    Inexpensive
    Disadvantages of peer to peer networks include:
    Difficult to expand (not scalable)
    Difficult to support
    Lack centralized control
    No centralized storage
    Client/Server In a client/server network, hosts have specific roles. For example, some hosts are assigned server roles which allows them to provide network resources to other hosts. Other hosts are assigned client roles which allows them to consume network resources. Unlike peer to peer networks, hosts in a client/server network have different operating systems. Advantages of client/server networks include:
    Easily expanded (scalable)
    Easy support
    Centralized services
    Easy to backup
    Disadvantages of client/server networks include:
    Server operating systems are expensive
    Requires extensive advanced planning
    Geography and Size
    Local Area Network (LAN) LANs reside in a small geographic area, like in an office. A series of connected LANs, or a LAN connected across several buildings or offices, is called an internetwork.
    Wide Area Network (WAN) A WAN is a group of LANs that are geographically isolated but connected to form a large internetwork. When implementing a WAN, remember to provide local access to user resources to prevent a high rate of WAN traffic.
    Participation
    Private A LAN or WAN for private individual or group use which may or may not be secure. Examples include home and organization (small business, corporate, institute, government) networks. Intranets and extranets, although related to the Internet, are private networks. Both an extranet and intranet are tightly controlled, and made available only to select organizations. An extranet is made available to the public and an intranet is made available internally.
    Public A large collection of unrelated computers, with each node on the network having a unique address. The Internet, for example, is a public network. Because computers are unrelated and many companies and individuals share the same communication media, the public network is by nature insecure.
    Signalling
    Baseband Baseband signalling allows one signal at a time on the network medium (cabling).
    Broadband Broadband signalling divides the network medium into multiple channels, allowing several signals to traverse the medium at the same time.
Jul 08, 2009 | 1995 Cadillac Seville
C13 ...same problem!!!!
Easy implementation
Inexpensive
Easy support
Easy to backup
Geography and Size
Participation
Signalling
Jul 08, 2009 | Sony MDS-JE480 Mini Disc Player
1991 SAAB Turbo dies when running as I approach intersections
Assuming this is a 900. Check the ignition lead from the dizzy to the igition pack. I once had a similar problem, and also check for ANY air pipe leaks. These cars are especially sensitive to air leaks. Look especially at the manifold pipes. Also, make sure tha intercooler pipe is secure. Is there any excessive smoking through the tailpipe?
May 10, 2009 | 1991 Saab 900
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
