Question about Belkin N1 Wireless-N Wireless Router
I have a Belkin N1 Vision Wireless router and its performance is poor, i have checked it via the pingtest site and it constantly has a packet loss of 20% or higher and poor stats re ping and jitter tests which put it in the d,e or f rating which is very poor. The modem has been checked and is running fine. It is a 20mb broadband connection but this poor performance leaves the internet connection slower and any streaming breaks up or stalls. Please can you help?
  • 1,472 Answers
PAULUS
The first question I have is have you tried connecting to router via wired and wireless and ran the tests to see if the issue is with your wireless signal.
Then next thing to look at is connecting your modem to your computer and run the same test because the problem could be with your connection in your area. Note even through your modem is working properly you still could have bandwidth issues in your area and your ISP may not tell you that there is an issue like that in your area.
The last thing to look at is how long you have had the router for. If you have had the router for serveral years it is possible that it is just time to have the unit replaced.
Let me know if you have any more problems or questions.
Issken
Posted on Mar 29, 2010
Belkin n1 vision router freeze up. download mode or looping in bootup mode. what next?
Disconct wireless devices...connect to pc via cable...Go to SSID settings... change bandwidth from 20/40mhz to 20mhz only ... rebooting issue will be soloved... link speed will show 65-150 Mbps .. bt dont worry.. u will get the whole bandwidth available .... after that reconnect wireless devices ... it wont reboot by itself ...
Jun 19, 2011 | Belkin N1 Vision Wireless Router
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
My belkin N1 vision, keep disconnecting from internet. my landline pc works fine. i am only having the problem when connecting with my laptop. i am using a mac book pro with mac os x latest edition. thanks
My N1 Vision does the same thing, If you turn off the guest account, you should find its ok. Only when this Guest account is on, thats when it disconnects. Hope this helps. John
Oct 03, 2009 | Belkin N1 Vision Wireless Router
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Can I use my belkin N1 Vision as a bridge?
It can't be used as a bridge but you can use it as an Access Point. All you need to do is disable the DHCP server of the router and don't use the Internet/WAN port
Apr 01, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 Wireless-N Wireless Router Logo
178 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
