Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
The display keeps flashing when it's turned on. it settles down after 30 seconds
  • Hotpoint Master
  • 3,463 Answers
Could be bad connection to the door lock, or the door lock starting to fail, if it is starting to take longer than usual to start, then it is the door lock that is failing.
Hope this helps.
Posted on Jan 30, 2010
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
I had my oil changed and they could not get the oil life % to reset. they held the button in for 30 sec. let go reheld for 15 sec. did not work is there anything else I can try?
Try this;
1. press the reset button on the instrument panel until "oil life" is on display.
2. when you get to "oil life" hold the button in until the display starts to flash the word "cancel"
3. "Cancel" will be flashing so turn the button one click counter clockwise until "oil life" is flashing.
4. press it for a second then release it and the whole display will flash.
5. after you release it then hold it down again for about 5 seconds and it will reset to 100%
May 11, 2011 | 2009 Honda CR-V
My machine keeps flashing f and h and keeps stopping mid cycle......help!
Hi
FH error indicates no water detected entering the machine or pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You'll need to Press PAUSE/CANCEL twice to clear the display. Please post a comment if you need more help.
Thanks
Rylee
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My hotpoint washing machine wt741 will do nothing except fast spin, LED display is flashing TEST, it will not stop doing this unless i switch if off, what can i do?
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Unplug your appliance before working on it
Thank You
Sep 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do I get the maintainance required light off
Turn the key off, hold down the odo button on the dash, turn the key on and keep holding the odo button for about 7 seconds. The display screen on the dash will start to flash, release the button and press it down again and keep holding it until the display stops blinking. All done.
Aug 24, 2010 | 1997 Honda Civic
How to get rid of maintance required light
1. Turn on the ignition and make sure it is on your odometer display, not the trip display.
2. Turn off your ignition. Hold down the trip meter reset button and turn the ignition on. Keep the button pushed in.
3. The maintenance required light will flash for a few seconds. when it turns off, let go of the reset button.
The the display will change for 1 second and go back to the mileage. That's it.
Jul 06, 2009 | 2005 Scion xB
Lights keep flashing when printer is turned on
The question is what light is flashing? One thing you can do is turn your system off. then unplug your system from your wall outlet...wait 15-30 seconds...plug it back in and then turn on your system..this may work out wise I need to know what light is flashing on your display.
Jun 10, 2009 | HP OfficeJet V40xi InkJet Printer
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
70 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
