Question about Frigidaire Dishwashers
I have a frigidair dishwasher FDB1050rem1. The clean light never goes out until I unplug then replug. This started about the same time that the dish washer started to make a loud clicking sound wile washing. The dishes are clean when the cycle is done.
SOURCE: My Dishwasher does'nt dry my dishes.
set the sanitize button and they will dry
Posted on Dec 30, 2006
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
appldoctom
  • 311 Answers
SOURCE: Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Posted on Feb 25, 2009
SOURCE: drainage problem
I had similar problem and rerouted the drain hose like papps54 said. I still had the condition and decided to pull out the drain hose completely to see if there was any debris trapped inside the hose. There was! I removed the hose from the machine completely, cleared out the debris, and let the hose soak in white vinegar overnight. In the meantime, I looked back up the drain outlet and found evidence of debris lodged in there as well. I didn't completely dismantle the dishwasher at this point but I did eventually clear it out as well as the drain filter located inside the dishwasher. After reassembling the drain hose and dishwasher, I cleaned it with baking soda for three nights and now it runs very well with no odors. Runs quieter as well.
Posted on Jan 10, 2010
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend,
I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions:
1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off.
5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher.
6. Close and latch the door and allow cycle to finish.
Note: If these conditions persist, a home water softener should be considered.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
My washer runs a very long time and doesn't dry the dishes but the light comes on
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 14, 2011 | Frigidaire FDB520RH Builtin Dishwasher
My dish washer dose not start, it keeps yieling "
Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
Regards: VOTIT
Dec 03, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher 15 months old. just started not washing dishes very well. set it for high temp wash. put plenty of fresh dishwashing liquid in. the unit goes thru a full cycle. you open the door and...
First I would check to see if it is getting enough water. There is a screen in the water inlet valve that tends to pick up debris. Follow the links Dishwasher not cleaning starting with the video on the water inlet valve.
Nov 05, 2010 | Frigidaire Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher heated dry way too hot
Wow. So glad to hear that you had no permanent damage.
Jun 19, 2009 | Dishwashers
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
108 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
