Question about Maytag Washing Machines
Tub overflows - Maytag Washing Machines
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear
Posted on Jan 30, 2010
For a tub overflow washer (Part# PPC826-3) where should the "thick end" go - top or the bottom? Is pasting a little silicone recommended on it so that it has a better seal after I tighten the screw?
The thicker end goes up because of the sloped end of the bathtub. You should not need to apply any sealant - the gasket is compressed as the screw is tightened.
Dec 06, 2016 | Plumbing
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
How do I remove a geberit waste and overflow fitting
Tub overflows have a connection behind the drain flipper. You will also need to get under the tub or into the wall behind the flipper to cisconnect the nuts connecting the drain pipes.
Oct 11, 2014 | Home
Water will not drain with lever in either up or down position
Assuming you have a lever operated tub stopper, with the lever mounted in the overflow plate, a common malady is the decay of the internal end of the lever, leaving the stopper at the bottom of its pathway preventing drainage.
remove the overflow plate and carefully slide the stopper assembly out of the overflow... you will know almost immediately if the assembly has come apart. if its intact, run a small diameter sewer snake down the open overflow to clear the tub's drain trap. if it has indeed come apart, remove the connecting rod and stopper from the overflow, you may have to fish for it some. Happy hunting....
reassembly is simply reversing the removal process once you have replaced any broken parts or cleared the trap.
Aug 25, 2014 | Plumbing
Need a waste system for my ceda roma whirlpool bath
What you need to search for at your local plumbing store is an EXTENDED overflow. An overflow for a jetted tub is taller than for a soaker tub.
This is taller than a regular overflow.
This needs to be between 22-28" tall.
Rod
US Parts Center
888-521-6183
Feb 26, 2013 | Home
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Overflow outside bathroom dripping how do Ifix it?
Just make sure that the over flow is tight with gasket in place. And all fitting's tight behind wall goin gto tub overflow. If it is check out out next step
1-This is a common issue that comes up. Make sure that the shower valve plate is sealed and tight to tub wall. Reason why I ask that is when you take a shower water will find a way out, down the plate or if tile at the point of where it meet's tub. And will look totally like it's the overflow every time.
May 23, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Frigidaire GLWS1339EC Washer Overflowing
Do not blow to the switch. Blow from the switch to the tub. The blockage is soap scum in the air bell on the side of the tub. You may have to run a small wire into the tub area where the air hose attaches on the side of the tub.
Dec 05, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Eljer garden garden tub drain
Tub overflows are not required in all states but I highly recommend drilling the hole and installing the proper waste and overflow drain I recommend the Gerber brand and also when you set the tub you need to set it in a light concrete for stability I use great stuff foam for setting tubs 2 cans spray on floor and set and level tub tub will never wobble or move
Nov 08, 2009 | Plumbing
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
