Question about Polaroid A530 Digital Camera
It turns on and off by it self - Polaroid A530 Digital Camera
I just had the same problem..tried bending the tabs and got the same results.......off and on, off and on. New, as in brand new, fresh batteries seems to have solved it. I put batteries that I had stored in it to no avail. NEW FRESH BATTERIES
Posted on Jun 19, 2010
  • 20 Answers
The battery enclosure has a couple metal flaps that make contact with the batteries, try prying it out a tiny bit so the connection is more secure and stops behaving erratically.
Posted on Jan 30, 2010
How do I turn off this self timer?
To cancel the self-timer after it starts, press the DRIVE button. To turn off the self-timer, press the DRIVE button and select a non-self-timer mode. See page 82 of this manual: http://www.fixya.com/support/p1660907-canon_eos_60d_digital_camera/usermanual-CA543C2-pdf
Oct 11, 2013 | Canon EOS 60D Digital Camera
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
30 " self cleaning oven,
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
How do i turn on the bake option on the self cleaning oven?
to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
Mar 19, 2009 | Pentax Optio 60 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Self Cleaning feature
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir
to capacity with a mixture of 1/3 white vinegar
and 2/3 water. Press the Self Clean button.
When the self clean light glows, turn the
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
The coffeemaker is now in Self Clean mode.
One cycle should be sufficient to adequately
clean the coffeemaker. When the cycle is
completed and the five beeps sound, the coffeemaker
will shut off. Turn the coffeemaker
ON to see if the Self Clean light continues to
flash. If it does, turn it to OFF and then repeat
the cleaning procedure with a fresh solution of
vinegar and water.
If the Self Clean light no longer flashes, turn
the coffeemaker to OFF and then run one
cycle of fresh cold water through the unit
before using the unit again to brew coffee.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
Feb 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Polaroid A530 Digital Camera Logo
140 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
