Question about Hotpoint Dryers
My hopoint dryer ctd00 isnt spinning round how do i get to the belt please?
  • Hotpoint Master
  • 3,463 Answers
Remove the top cover and right hand side panel looking from the front, this will give you access to the motor and belt.
Please rate my solution.
Thankyou.
Posted on Jan 30, 2010
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
The drum wont spin on my Hotpoint CTD00 dryer
Remove top cover, and see if the belt is intact, if it is then it could be the motor is not working for one reason or another, this would entail further investigation.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Belt dhange
Please provide the exact model number or the brand name so that i can provide some internal diagrams that might help you out.
Jan 17, 2009 | Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
85 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
