Pilot light will light, but when we turn knob to turn heater on the pilot goes out
  • Heating & Co... Master
  • 2,799 Answers
Hj clean pilot out may be too short or check thermopile or thermocouple 1 of these might need replacing
Posted on Jan 30, 2010
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
I light the pilot light and it stays on. When I turn the heater on I hear a click and the pilot goes out.
The pilot light must be BLUE and fully enveloping the thermocouple if its dirty...it becomes yellow and or too small to heat the thermocouple properly...if it goes out as you turn the knob to on then the valve is likely defective
Oct 26, 2009 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Pilot light goes out every time heater reaches & missing knob
the thermo couple thing that pilot heats up is not staying in flame if knob is broke you may be able to heatup manualy to get gas valve to open some will wome wont
Jun 10, 2009 | Heating & Cooling
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
Windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Feb 29, 2008 | Endless Summer 2009 Open Flame Patio...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
