Question about Whirlpool LER4634J Electric Dryer
Will not run
Was running no heat i shut off now will not restart
  • Gary Davd
    Gary Davd May 11, 2010
    no heat is maybe a thermal fuse
  • Gary Davd
    door switch ok??
Dryer will not turn on at all but was running and heating fan previously. Any ideas?
Posted on Aug 08, 2008
    Problem Solver:
  • 12 Answers
Check your recepticle .most dryers will run on half power but willnot heat. if your recepticle is bad ` it may have lost all power.
Posted on Feb 28, 2008
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 24, 2017 | Heating & Cooling
Microwave runs good for short heatups. But long or repeated heatups the microwave gets warm and shuts down. Will restart after cool off.
Magnetron thermostat is sensing over heat condition, it the fan running to cool it while running
Nov 21, 2015 | In Microwave Ovens
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Computer shutting off
shutting off when? Shutting off immediately when you try to start it? Shutting off after it has run for a while?
If it is shutting off after it has run for a while, then it is probably running hot. If you try to restart it immediately it will not boot. If you let it cool off for a while then it will boot successfully (definitely a sign of running hot).
Things that make a computer run hot:
1) Dust in the vents, fans, cpu & heat sink and all inside the computer.
2) Fan not working
3) The Thermal Paste on the cpu and heat sink has either dried up or is too thin to keep it cool.
If it shuts down immediately after it has been sitting for a while then it's not running not and your system has some other problem.
Mar 31, 2012 | Computers & Internet
Car runs great until you have to sit in heavy traffice and will then shut off. If you pop the hood and let it sit for 5 minutes it will restart. There is a tremendous amount of heat that comes out from...
I f the engine is running too hot replace the thermostat, more than likely the ignition module is malfunctioning upon the heat threshold replace it.
Nov 05, 2009 | 2000 Mazda Protege
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
91 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
