Question about Samsung SyncMaster 940N Flat panel Monitor
Samsung SyncMaster 940n monitor that turns on then goes black
I have a Samsung SyncMaster 940n monitor, three years old, it comes on for 5-6 seconds then turns black. It doesn't attain the normal blue color before going black. Other posts suggest needing to replace a capacitor and fuse. Is this what I need to do? And what is a good source for these parts?
  • rcpips Feb 01, 2010
    Thanks for your quick response. You said "bad news if I find CAPXON" caps in unit. Well that's what I found. Also after careful visual inspection, I have yet to find any broken or cracked solder connections nor do I see any caps that visually look distorted on either board. I will continue to inspect, but if you have any further suggestions, I welcome the input.
    On another post,http://www.fixya.com/support/t2748440-mo... my board looks the same and the problem is similar. But I still don't see any visible evidence the cap shown there is a problem in my case. But I would replace it and try it if that is the most likely problem.
    rcpips
  • rcpips Feb 02, 2010
    rcpips
  • 732 Answers
Rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
  • Louis Ebert Feb 02, 2010
    rcpips, go to www.thinksrs.com to see my lcr meter. here are some readings of capacitance of CapXon failed units I have removed. 2200uf 16v =45.2uf, 1500uf 16v=9.01uf, 1500uf 15v=4.9uf These units have only very slight swelling of their top aluminum "can". Other units with more swelling are just as bad. If possible remove some of them and have a local tech at a tv /or other repair shop measure them. I wonder what Samsung would say if you told them what you found??? Keep me posted on this issue!!! 12fixlouie
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
And here is the a picture of the power supply board.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 940N Flat panel Monitor
My monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Aug 10, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Samsung syncmaster 913c
press the blue fn button and look for a screen on the buttons F1 through F12
Jun 17, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Samsung SyncMaster 940N Flat panel Monitor Logo
2,200 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
