Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
When a CD is selected, it's starts to spin, I hear 2 clicks and it stops spinning. This happens a couple more times then the CD is ejected and returned to it's slot.
  • 98 Answers
It sounds as though either your CD player (probably a CDM3 or CDM4S) of the CD control box is defective. I would be happy to help you troubleshoot further over the phone and can provide repair and/or replacement of the defective components. Please email tech@wurlitzer-ohio.com. Thank you, Rod Stebelton
Posted on Jan 30, 2010
Vauxhall insignia dvd800
Laser is offline. Needs to be serviced or junked.
Mar 10, 2014 | Car Audio & Video
After selecting disc it spins a few times then stops and ejects
Hello
The laser pickup unit is defective. Replace it with same type and number. OK.
Jan 15, 2012 | Wurlitzer Jukebox CD Player
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Whirlpool Dryers
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
The cd gets ejected without being read.
As long as it does that on more than 1 disc, it can be a couple of things. The lid has to be taken off so you can see and listen to what is happening. #1 If it takes it all the way in and spins the disc, it most likely cannot read the disc usually because the laser lens needs to be cleaned or the laser is defective. You will hear the lens going up and down, making a clicking noise over and over and then it ejects it. #2 If it cannot load it all the way in and does not even spin the disc, it is usually a rubber loading belt is slipping and needs to be cleaned or replaced. You will hear the motor running and running without taking the disc all the way in. It will never spin the disc, then eject it. Other things can cause it also but those 2 are the first things to look at. :)
May 19, 2010 | Audio Players & Recorders
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Same problem
Hi. I had a similiar problem a couple months ago. May possibly be the motor coupling.
Take a look at the problem that I posted:
http://www.fixya.com/ThreadAsker.aspx?thid=2046342#
Select "View Other Solutions". Number 3 posted a video that shows how to replace the coupling.
Hope this helps. Thanks for using Fixya.
Aug 13, 2009 | Washing Machines
Hello .Sometime does not play track
It is having trouble reading the CD.
Either....Dirty CD. Dirty laser eye. Duff CD. Duff laser unit.
One More Time does not like CDs made on your computer too.
Jul 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Unit won't read CD
The thing with Head Units is unless you take it to a guy that specialises in electronics to give the full problem, it's better to replace the unit. Also repair might cost a fortune. Can you get warranty?
Feb 11, 2008 | JVC KD-LX30 CD Player
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
122 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
