Question about HP Photosmart 3210 All-In-One InkJet Printer
HP photosmart 3210 cartridge door locked up
Open door and changed ink cartridge, the door will not come down. what do I need to do?
Thanks
  • Anonymous Apr 22, 2008
    the door wont come down!
    Novelist:
  • 188 Answers
Please click on the web link given below and perform the steps as provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00786043&cc=us&lc=en&dlc=en
Please do it carefully.
Have a great day!
Posted on Mar 27, 2008
HP Photosmart 3310 All-in-One Printer - I opened the ink cartridge door & it now seems locked in open position - won't close.
Your printer does have a lock that clicks in when you open the printer to replace ink catridges. The User Manual has no specific comment on steps required to release the lock.
Is there a release tab/button that you grip when lifting? If so, suggest you try pressing this same release as you lift the cover, lifting slightly higher to see if the lock will disengage allowing you to close.
If no release tab/button simply try lifting slightly higher as above to see if the lock will disengage.
If either of these does not resolve isse I would inspect losely to see if there is a way to disengage the lock; simply using more force may result in damage.
Dec 22, 2010 | HP Photosmart 3210 Printer
Photosmart 3210 bought Dubai need to change region Spain
Hello Friend
You can change region settings of your hp 3210 printer by changing your language preferences.Just select the language of your region and it will be fine.
Thanks,
Viju
Apr 03, 2010 | HP Office Equipment & Supplies
My HP Photosmart 3210 printer is not printing black color
must be dryed ink on ink cartdrige, or dirty print-head (ink cartdrige) conntector.
try these :
To clean the print head from the control panel
1. Load letter or A4 unused plain white paper into the main tray.
2. Press Setup.
3. Press 5, then press 2.
This displays the Tools menu and then selects Clean Printhead.
or
To clean the ink cartridge contacts
1. Unplug the power cord from the back of the HP All-in-One.
2. Lift the ink cartridge access door.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
4. Inspect the ink cartridge contacts for ink and debris buildup.
5. Dip a clean foam rubber swab or lint-free cloth into distilled water, and squeeze any excess water from it.
6. Clean only the copper-colored contacts.
7. Place the ink cartridge back into the empty slot and press down on the gray latch until it clicks into place.
8. Repeat if necessary for the other ink cartridges.
9. Gently close the ink cartridge access door and plug the power cord into the back of the HP All-in-One.
These steps is printer manual on pag 99 and 100
Jan 15, 2010 | HP Photosmart 3210 Printer
My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
Jul 16, 2009 | HP Photosmart 3210 Printer
Re-configuring for european ink cartridges
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
Apr 25, 2009 | HP Photosmart 3210 Printer
My HP Photosmart 3210 thinks the ink cartridge is still empty even though I have replaced it.
Very simple cartridge. Check the chip on the bottom to be sure that nothing is on the contacts. Try installing the old cart and see what happens. Fortunately, these are not very expensive. Install the old one, unless you ran it until it locked the printer out.
Mar 08, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
142 people viewed this question
Ben Johnson
