Question about Telex EDAT D/A Conversion Card, XGEN, 110V (300802001)
Can you help me with convert 0.00238 m to micrometers 1 micrometer is equal to 1/1,000,000 meters.
I have a fowler IP54 outside caliper micrometer 7-8" that is zeroed out. There are only 2 keys, a mm/in and zero. How do I reset to have it read 7.0 at 7.0?
Generally, micrometers are "zeroed" to a standard -- an object of a known specific length or diameter. If you have placed a 7-inch standard in the micrometer and brought the spindle into proper contact with that standard, and then zeroed the micrometer at that point, it will be properly set to seven inches. Standard micrometer travel is only one inch, and only that range is usually displayed. The user must then add the standard length to the face display or thimble reading to get the "developed" measurement.
Jan 08, 2015 | Fowler Measuring Tools & Sensors
How do i find the millionth of a inch on specs in the govenor assembly on my 1972 yamaha 125
I think you have misread the spec. A millionth of an inch is not something that you can measure using normal micrometers, vernier's, feeler gauges etc. If you take an inch as 1 then a millionth is 0.000001 inches. If you have seen the word mil in the spec this actually equals 1 thousandth of an inch or 0.001 inches which is more likely. Example 5 mil = 0.005 inches, micrometers, verniers and feeler gauges can all be used to measure this dimension.
Dec 26, 2014 | Yamaha Motorcycles
What are the absolute uncertainties of a micrometer and the vernier caliper?
This depends on the original specification of the device and upon it's current condition. Mechanical gage calibration deals with this all of the time, when they calibrate these devices against known standard fixed dimension gages. These reference gages also have uncertainty as well. But in general, good quality "thousandths" inch micrometers are typically good within about 1/3 of a thousandth across their entire range. Good quality "tenths" mics in good condition are expected to be within a ten-thousandth across their range. Good luck, Al K
Mar 08, 2011 | Fowler Outside Micrometer Set 0 - 4"
Spindle movement jammed
it has something stuck in it...do not try to force it
send it to an authorized Starret repair facility to be repaired
May 16, 2010 | Starrett T216XRL-1 - MICROMETER, DIGITAL
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Jul 28, 2009 | Mitutoyo Measuring Tools & Sensors
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Thimble on 0"-1" micrometer is tight.
spray some silicone into the thread areaand open and close it a few times.
Mar 04, 2009 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Does conventional micrometer use to measure radial runout
No...
that type of hand tool is to be used on items that are idle.
Serious injury and product damage can occur if an attempt is made to clamp this tool on to a moving part.
It would seem that a dial indicator might be the tool of choice for you.
Good luck
Feb 22, 2009 | Central Tools Conventional Micrometer 0 To...
Telex EDAT D/A Conversion Card, XGEN, 110V (300802001) Logo
35 people viewed this question
Top Telex Televison & Video Experts
Electro Med Services...
Are you a Telex Televison and Video Expert? Answer questions, earn points and help others
