Question about Samsung LE26R72B 26 in. HD-Ready LCD Television
Hi i have a samsung lcd tn model le26r41bd when powered on picture flickers with lines down screen. it does it on all inputs. but if i press still on remte picture goes clear
  • 201 Answers
Sounds like a main board issue. Since the picture clears up in still that rules out a bad panel or t-conn (interface pcb between panel and main)as it would look bad all the time. The main pcb handles all the audio and video processing so that is the most likely suspect.
Posted on Jan 30, 2010
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 12, 2017 | Samsung Televison & Video
The picture has a pink and reddish hue
Any magician can make a trick look easy - but NOTHING replaces years of training and experience. That said, here's your answer:
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button. Then press the POWER button for two seconds. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice)
Scroll down to: “TA1383” then (Arrow right)
Scroll down to:
CONTM1: _______
CONTS1: _______ (Press exit)
After writing down these values, please continue:
Nov 11, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
LG 55LD520 picture problem
the problem with these sets (all brands) is it could be any board in the set or even the panel used for the display---
Jun 06, 2012 | LG 55LD520 55 in. HD Ready LCD TV
Hitatchi - Ultravision Digital 52" - Pink screen
Good Day,
TRY THIS:
Before you attempt any repairs, it is necessary to make a test. The results of this test will determine which part may need replacing. Please follow the directions.
In short, you will be doing the following:
  1. Perform Memory Initialization. NOTE: You must write down some data values before performing initialize. (See Below for Procedure).
  2. Check this status of the picture. (See Status after Initialization)
  3. The status will determine what part need replacement.
FOLLOW THE ORDER BELOW:
(01)
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS: (See Below)
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  3. Then press the POWER button for two seconds.
    • You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    • If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
(02)
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice) .
I hope this was helpful, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink screen
possibly a bad light engine (not cheap).
Oct 16, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung LE26R72B 26 in. HD-Ready LCD Television Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
