Question about Maytag MMV4205 Microwave Oven
Maytag microwave mmv1153aaw
Our 2-year-old microwave all at once started humming very loudly and issuing smoke and burning electrical aroma. I know the smell of burning grease, and it's definitely not that. The turntable still turns, and the fan (not vent fan) still runs.I suspect magnetron. Am I right?
  • 1 more comment
  • Cheeesy Feb 18, 2008
    No, it's not the wave cover. I took that off and checked it per earlier advice I read. It is clean and unburnt. No, it doesn't heat the food at all. My son was using it to pop a bag of popcorn, and it popped only half of the kernels
  • Cheeesy Feb 21, 2008
    drcool299 was right on the money. Unfortunately, I had already taken my microwave to the repair shop. It was a diode, though I don't know which one. The shop said it was "in the capacitor." Thanks much! Wade
  • Anonymous Mar 13, 2014
    the microwave enhaust fan comes on without warning. i turn it off by pressing the vent button and hours later it will tuun on again. what can be done
  • 958 Answers
My guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Posted on Feb 18, 2008
  • francis rivero Feb 19, 2008
    try checking the industrial diode that is connected between the capacitor and the ground of the unit. check also if there is a diode in between the terminal of the capacitor. if there is, check that one too.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My 8 year old Maytag over the cooktop microwave does not heat food, but all other functions seem fine. There is a new, loud noise, similar to an electric motor that is seized.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 25, 2010 | Maytag Microwave Ovens
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
I have a 1000watts maytag microwave MMV1153AAW the condenserfan was running by itself on and off i disconnected the wire bacause it drove me crazy now the transformer is sparking up on me is the any...
Unfortunately, if you have cut a wire internally then any warranty will be void.
Have you investigated why the transformer is sparking? This sounds like either a serious problem with the transformer or simply a loose connection.
I assume when you cut the wire you have made sure that it is insulated from the chassis?
Mar 21, 2010 | Maytag MMV1153A Microwave Oven
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
COINCIDENCE? Yes... :) So go buy another one, it'd probably be cheaper than getting the bad one repaired.
Geno
Feb 25, 2008 | Maytag MMV4205 Microwave Oven
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Maytag MMV4205  Microwave Oven Logo
563 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
