Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
DO I NEED TO RUN HOT WATER IN THE NEAREST FAUCET TO START THE DISHWASHER
  • 72 Answers
This model does have an inline heater to heat the water to the proper temperature, but it does take a long time and you are recommended to run the tab on the faucet from which the dishwasher water line is tapped from. This clears all the cold water from the line
Posted on Apr 08, 2010
Ex500isc displays error 20
Have you tried making sure the water entering the machine is very hot by running the attached faucet Mr. Burns?
We had this happen when we turned our water heater down to it's minimum setting and forgot to run the kitchen faucet (supply was also plumbed to the dishwasher) until fully heated up, then switching on the dishwasher.
Mar 27, 2014 | Electrolux Dishwashers
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Mixing bowl still had flax dough in it when dishwasher was started and now no water comes out of the wash wands and the screen is plugged! what should I do???
My suggestion would be to clean out congeled stuff in the spray holes with a wire to open the holes to start with..
Then run a VERY concentrated detergent, empty load cycle.with very hot water. Run your kitchen faucet until you have real hot water before running the dishwasher.
Dec 21, 2009 | Maytag Dishwashers
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
My dishwasher is filling up with water but the water want get hot
The water needs to be hot before it goes into the dishwasher. Just before you start the machine, run the hot water faucet until the water gets hot.
Some dishwashers have a heat boost feature to sanitize the dishes, but it's not intended to take cold input water and make it hot.
Nov 12, 2008 | Dishwashers
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
GE Monogram ZBD0700K - gel pak detergent not dissolving
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Jun 20, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
Dishwasher
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
77 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
