WHERE IS THE MEMORY FITTED ON A SAMSUNG A SERIES A10 LAPTOP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Usually on the bottom of your laptop there's a small panel with one or two small screws you can easily remove. Make sure you pull the battery and the power cord out before doing anything. Look for the small panel on the bottom and look in there for one or two small rectangular circuitboards. Most likely that's your RAM, unless it has wires connected, in which case, that's your wireless. Gently move the clips outward on either side of the memory stick and it will pop up at an angle. Gently remove it and replace. Insert the new one at an angle all the way in, then tilt it flat down so the clips hold it in place.
If nothing is on the bottom of your laptop, then the memory lives underneath the keyboard. Try the Samsung website for instructions.
Posted on Mar 08, 2010
Installed new WD HDD (160Gb) into Toshiba Satellite A10-S167. Entered BIOS edit, but can't get laptop to recognize the new HDD (which replaced a smaller, failed HDD)
Shouldn't have any problems on the A10 series working with a 160GB drive, so long as it's an ATA/IDE type with a 44-pin connector. If it's not recognizing the drive, could it be that the pins were not precisely lined-up with the IDE connector? I'd remove the drive, make sure the pins are still all straight, reinsert it into the HDD compartment and see if it makes a difference.
Aug 31, 2011 | Toshiba Satellite A10-S167 Notebook
Bridge media slot - is this where I can insert my memory stick from my digital camera?
Yes.. you should if it fits your Camera card. If not you can buy adapters to make it work.
Mar 24, 2011 | Toshiba Computers>Laptops Satellite A10 PC...
Why does Toshiba satellite a10-S177 have 1gb ram limit? Motherboard? BIOS? Or just that 1GB SODIMMs weren't invented yet?
Motherboard
More specifically the motherboard chipset.
The motherboard chipset is the Northbridge chip, and the Southbridge chip.
{In reference to the motherboard chipset technology used for this laptop}
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of a computer.
The Northbridge chip determines what Processors can be used, what Ram Memory can be used, (Plus the amount), and High-speed graphics.
AGP and PCI Express being High-speed graphics.
A graphics card inserted into a PCI expansion slot is not High-speed graphics.
Neither is Integrated Graphics.
The Southbridge chip handles the slower capabilities of a computer.
{CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short}
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The motherboard chipset for the Toshiba Satellite A10 series of Notebook PC's, is an
Intel 852GMV.
The maximum amount of ram memory supported is 1GB.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4-M.2FPentium_M.2FCeleron_M_Mobile_chipsets
http://www.intel.com/assets/pdf/datasheet/252407.pdf
Regards,
joecoolvette
Dec 16, 2010 | Toshiba Satellite A10-S177 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          How do i replace the memory in a toshiba satellite A10?
          there is a small access panel under the laptop with 2 screws..
          Nov 12, 2009 | Toshiba Satellite A10 Notebook
          Toshiba Satellite Pro A40 Can't find RAM memory
          The memory is located under the keyboard
          Remove batt and cables
          open screen
          pop out the rectangular panel surrounding the on off buttons
          remove the 3 screws and lift up the keyboard to access the memory
          Dont ask me why they made it this complicated
          Manual can be got here
          http://209.167.114.38/support/download/files_downloads/SA40/SA40EXUM.PDF
          Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
          Drivers for satellite A10 PSA10L-024F4P
          Go to Toshiba Support & Downloads Site
          Choose:
          Product Type --> Archive
          Family --> Satellite
          Product Series --> Satellite A Series
          Model --> Satellite A10
          Scroll down and click "search"
          Scroll down and start downloading drivers and utilities for your laptop.
          Aug 21, 2009 | UltraLast FOR TOSHIBA SATELLITE A10/A15...
          When 4 gig. sd hc memory card is loaded into camera CARD IS IN ERROR msg. appears on lcd screen. Any ideas???
          The A10 uses SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with the A10. You need to use SD cards, 2GB and smaller.
          Apr 12, 2009 | Pentax Optio A10 Digital Camera
          Toshiba A10 notebook
          The recommendation on the net appears to be to remove the battery, then the modem. Then re-fit and re-install it. There is something dodgy about these notebook connectors.
          Nov 09, 2008 | Toshiba Satellite A10-S100 Notebook
          Computers & Internet Logo
          23 people viewed this question
          David Payne
          David Payne
