Question about Hotpoint Washing Machines
We had a power cut when the machine was on and now the on button flashes on and off but does not do anything also the crease and rinse hold buttons flash
  • Hotpoint Master
  • 3,463 Answers
Try switching it off, leave for a few seconds, and then switch on again, press start and cancel button if it has one, and hold for 3 seconds, then try a programme again.
This may work, but as you did not state the model number , the sequence can differ from model to model.
Hope this helps.
Posted on Jan 30, 2010
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
How to fix washing machine
1)test the button for open or defective with a VOM see the diagram and how to do it.
2) the board can be faulty. however resolder all the colder joints+ tight very well all connectors wires, and proof again. God bless you
Jun 19, 2012 | Washing Machines
Hi, I have a Hotpoint WD440 Wash / Dryer. When switched on at the mains electricity the "Rinse Hold, Reduce Creases, Drying Heat, time saver, dry and on/off buttons all flash for approx 5 mins, then...
The flashing lights are an error code (Which I can't quite figure, but I believe ARE associated with a blocked filter. Is it possible that the slime and mess extended beyond the filter?
Before you go throwing the machine away, Unplug it from the mains (NOT just turn it off) to allow the machine to reset and while it's unplugged, stuff your garden hose up the waste water pipe and turn it on full blast to blow any remaining debris out of the way. (Wrap a towel over the end of the pipe to soak up the spliiage as one will not fit neatly into the other).
As the Dr Pepper ad says - "What's the worst that could happen?"
Jul 07, 2011 | Hotpoint Ariston WD440G Front Load...
Bosch exxcel 1200 express washing machine not working, F63 flashing on display,are the brushes on the motor worn out?
I had F63 on Bosch washing machine (Maxx 7). I waited 5 days for a repairman and all he did was reset the washing machine processor, like this: 1. Turn the program knob to 6 o'clock 2. Hold the RPM button 3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse) 4. Release the RPM button.
This is similar to F21 which also happened to my machine. Apparently both errors are related to power surge/power cut.
Oct 25, 2010 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Flashing lights
I unplugged the machine...plugged it back in and hey presto it works.....simple!
Sep 05, 2008 | Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
