Question about Pentair Minimax CH Heater
Pentair minimax 200 m electrical installtion?
  • 990 Answers
Don't know just what your asking but if you want to know where it comes from. Wire the unit from the timer for your pump so it wont fire without the pump. Be sure to check the voltage on the pump and the heater will need to be wired the same (110-220V) This will be done inside the heater at the transformer. You will find instructions inside the panel of the heater.
Posted on Jan 31, 2010
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater. The fan does
if voltage to fan replace capacitor if no voltage check safety circuit
Aug 16, 2017 | Pentair Minimax NT Heater
Blue coating in filter from heater, copper?
It sounds like copper is the culprit. This usually happens from dropping the pH too low. You may have added too much acid. Heavy use of low grade algaecides can cause this as well. One last thing to check and make sure your not adding chlorine tablets in the skimmer. This will also damage the exchanger in the heater causing blueing. You may want to try a sequestering or chelating agent. Ask about it at your local pool supply.
Paul
May 31, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Heater Manifold Return Header Assembly 471991: I have water leaking from my minimax CH 200 heater...
This is likely a leaking heat exchanger. These usually fail due to improper water chemistry. This can happen in less than a year if the chemistry is messed up enough. Most culprits are putting chlorine tablets in the skimmer and running the pH or Total Alkalinity tooo low. HTH
May 17, 2010 | Pentair Heater Manifold Return Header...
Need to reignite the heater and the instructions on the panel are paritially destroyed. it is a minimax plus 250 and have tried finding the instructions on line
For an Owner's Manual for the MiniMax Plus heaters, which does contain start up proceedures for the electric and millivolt models, you can follow the link below.
http://www.inyopools.com/owners_manual/pentair_heater_minimax_plus.pdf
Make sure that you follow the directions for your particular model of heater.
Jul 05, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax 250 does not light everytime
that one think thats bad with pentair heaters they say when you turn one on stand to the right cause the door can blow off because the way there burner are set up u need to take out the burner trays and clen them this problem does not happen with raypak heaters
Apr 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair Minimax CH Heater Logo
176 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
