Question about GE (PSS26MSRSS) Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about 9 years old. Model GSS25JFMBWW
  • ectorp1 Jan 30, 2010
    Compressor does not appear to be running, I have unplugged for several mins and then back. The fan is runnning. Its almost like it is stuck in defrost mode. I am unable to find any mechanical timer, circuit board 200D2260G006 looks like its the controller. No apparent damage on the board and no way to debug found on the web. Way to bypass??
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jan 30, 2010
  • Charles T Nevin
    Charles T Nevin Jan 30, 2010
    The fans wont run when it's in the defrost mode. Check the starter/overload relay. If it's bad it may be burnt on the inside. See if it rattles when you shake it.
I have an old kenmore fridge maybe a 90's model it's an off white color probably from age and alittle rusty, it's a top freeze and the freezer works great but the fridge section can barely keep...
all the fridge does is the freezer gets cold and the evap fan blows cold air from the freezer down into the fridge section,so open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,also the drain can be blocked and it freezes up the air ducts so the air can't circulate down into the fridge,is there water under the bottom crisper draws?if so the drain in the freezer is blocked,you have to take everything out of the freezer,remove the back wall,melt out all the ice and clean out the drain under the evap coil.i use a steemer to clean out the drain,if you don't have a steemer you have to melt out the ice in the drain with the hair dryer,then get like a turkey baster or anything that can blow down into the hole,pour hot water into the drain,if it drains out then you're done,if it doesn't keep hitting it,another thing is touch the inside back wall of the freezer,if there's like frost or like snow covering the back in side freezer wall you have a defrost problem,bad defrost thermostat,heater or timer,the last thing is the door was left open,you can tell this by looking at the food packages and the ceiling and walls,if you see frozen water droplets on your food packages or on the shelf or walls the door was left open and the air ducts are frozen,you have to melt the ice out of the air ducts.so open the freezer door,listen for the fan,no fan could have a bad fan motor,look for ice on back inside freezer wall or frozen water droplets,the door was left open or you have a defrost problem. also when was the last time you vacuumed out the coil unless it's on the back wall,if the coil is behind the bottom kickplate vac it out that will make a big difference.you can get back to me and let me know what you find or melt it out with a hair dryer like i said.good luck and let me know what you find.one more thing,if your ice cream is not staying hard just soft you could have a leak in the sealed system,but if i were you i wouldn't put any money into that machine,if you change it out you'll save money on your electric bill and usually once something on those old dogs starts to go wrong it's not long before it totally dies
Sep 22, 2011 | Kenmore Refrigerators
MY G35 COUPE WILL NOT START UP...BUT IT DOES TURN OVER THE HEADLIGHTS DOES WORK AS WELL....IT WAS A BAD SNOW STORM LAST NITE...AND THE CAR WAS COVERED WITH SNOW....WHAT COULD BE THE PROBLEM....??THNX
Could you have a frozen gas line due to water in the line? Verify that fuel pressure is where it should be with a pressure gauge. Move the car to a warm garage and let it warm up if there is ice in the line. Always have more than 1/2 of a tank of gasoline in the tank when winter comes.
Jan 27, 2011 | 2004 Infiniti G35 Sport Coupe
Freezer is icing up inside snow/ice is building up inside the freezer especially in the top shelf. The fridge is also not so cold. The component that connects the fridge to the freezer is mostly blocked...
it may be the door seal not closing right up,and its letting in warm damp air,,,or it could be that the door is opend a lot of times in a day,,,all let in damp air witch freezes
Nov 17, 2009 | Refrigerators
Have a frost free freezer kids left door ajar all
You should unplugged and let all the ice melt and help it with a hair dryer.
Oct 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator with automatic The ice melts and leaks out the door?
Same problem with my unit. The plastic tray seems to warp over time and the water drips out of the tray prior to freezing into the cubes. I was able to purchase a replacement tray online. I also discovered a hidden reset button under the right side where the ice tray motor assembly is located. This button had to be pressed in order to get it to cycle through again after replacing the plastic tray. We'll see if this solves the problem of water spillage all over the interior of the freezer!
Sep 20, 2009 | LG LFX25960ST Stainless Steel French Door...
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
JCD2389DES Water Leak Problem
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
251 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
